Want to disconnect front swaybar, which side, driver or passenger?
I cannot remove it completely right now due to the pipes routing, so I just want to disconnect it. What's the easiest way, can I disconnect just the passenger side end link? Going to the track tomorrow so want to try that
Right, the two bushings in the center area of the bar support the weight and it's just dead weight hanging there.
Since you're lowered on good springs/shocks, I'd love to see if you miss it. Try driving the car spiritedly around some on/off ramps, curvy roads, then do the same after disconnecting. I bet you won't miss it unless you're really pushing the car hard. This was my experience at least...
Great. I probably wouldn't miss it honestly - as much as I like to drive my car, unless it is in a straight line, I rarely push it around corners for fear of it letting loose...and certainly not doing it with the ET streets on it at the moment, lol.
I'm planning on doing that and setting my shocks to full soft in the front to hopefully get some better 60's when I get my diff back. Couldn't break 1.92....but that was the first time out with the new setup and drag radials (ever), and a broken diff.
Even still, I'd rather not fully remove it from the car, even though it is not a DD. I do plan on upgrading to a hollow one in the future however.
I ran a 12.71 without it and
I ran a 12.71 with it
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I will assume in something faster or maybe something with traction issues there may be more of a difference.
It wasn't bad to drive on the street but I couldn't push the car into corners
