Drag Racing Tech
Brian Black's X275 TA Build at Midwest Chassis......
Old 11-28-2012, 02:37 PM
  #41
SMKN TA 95's Avatar
All panels on the car and ready to go to paint.....
Paint and electrical will be next on the upload list....
Old 11-28-2012, 02:47 PM
  #42
Reject's Avatar
daaaaaaaaaaaaaaaaaaaaang very nice! quick Q, why PC basically the whole thing? good deal?
Old 11-28-2012, 02:53 PM
  #43
ATVracr's Avatar
Very nice!!
Old 11-28-2012, 02:58 PM
  #44
SMKN TA 95's Avatar
Why, because we can
Much more durable than paint, looks better, smoother, and I have a good friend who does cars all the time
Old 11-28-2012, 03:00 PM
  #45
Reject's Avatar
haha i knew there was a hook up in there some where! looks great
Old 11-28-2012, 03:02 PM
  #46
SMKN TA 95's Avatar
At the body shop!!!
Old 11-28-2012, 03:06 PM
  #47
SMKN TA 95's Avatar
Outside Pictures!
The logo on the hood is completely air brushed by the painter.....this is all we had time to get done before the LS Fest, so we held off on the rest of the air brushing. The car is going back this weekend to get the rest of the air brushing done on the front end.....
Old 11-28-2012, 04:35 PM
  #48
RENE'S RAGE's Avatar
Brian, with that Joe Van O hood, is it pulling outside air in from the nostrials or the cowl.
Looks to me like the nostrials with that air pan. I'm wanting a hood like that bad!
Just wondering which way the motor get's it air from.
Thanks
Old 11-28-2012, 07:26 PM
  #49
Italiankid77's Avatar
where did you find the Joe Van O hood ive been looking for one?
Old 11-28-2012, 10:27 PM
  #50
LS1SpeedAddict's Avatar
Got any pictures of the rear set up in the car? Finished I mean. Beautiful job Brian, I don't think there's any way you could improve on it.
Old 11-29-2012, 07:56 AM
  #51
SMKN TA 95's Avatar
Thanks
When I run the air pan, it only gets air in the front of the hood(nostrils). When I don't run the air pan, it gets air from the nostrils and under the hood too..
I've had this carbon Joe Van O hood since 2007
Thanks! I will be putting up some more pictures of the assembly process of the car here shortly....and I've got some rearend stuff in there.
Old 11-29-2012, 09:05 AM
  #52
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,142 Likes on 742 Posts
Plimpton painted it? Car looked awesome in person this year.
Old 11-29-2012, 12:13 PM
  #53
SMKN TA 95's Avatar
Yes Plimpton painted it. Goes back soon to get the hood/roof/trunk air brushed with stuff
Old 11-29-2012, 03:45 PM
  #54
TheLS1Lover's Avatar
I love your car Brian. The powder coating the chassis thing was a cool idea. Do we get to see some of your wiring soon?
Old 11-29-2012, 03:51 PM
  #55
SMKN TA 95's Avatar
As most of you know, I own a company that builds custom electrical systems for race and street cars. I have been extremely busy with customer builds this year, but I was ready to do something for my own car and a little different than the rest. Since the whole car was torn apart and completely, I decided it was time to to start completely over with the electrical system in my car.
Normally I use Deutsch connectors on my panels, but for my own personal build, I decided to go with Mil-spec flanged connectors in black annodized finish. As I found out, these are a very rare connector to find in the style I was looking for. Definitely not cheap, but added up to a very nice fit and finish. I ended up using these on the panel, and the firewall for the BS3 and nitrous harnesses. I also combined both of my dash and overhead switch panels into one, 11 switch setup above my head.
On the BS3 side, I cut the harness and re-pinned it using those black mil-spec connectors. I have it split across two of them due to pinouts, splices etc. Everything BS3/DAE above the valley cover is setup into one connector, while everything below that is in the smaller connector on the right. From the firewall out to the engine, I completely redid the engine harness wiring. Every sensor is re-wired to the proper length for my engine and wiring location so there is no slack. I covered every bit of the EFI harness in Raychem DR-25 heat shrink which is surprisingly flexible. I used this covering along with the expensive raychem heat shrink boots for the firewall and the control panel harnesses themselves. I also switched to the AEM/Firecore COP setup from my stock LS truck coils. Due to the coils needing a new harness, I made new coil harnesses with splices etc from the firewall out to each side. Those pictures will be a little later.
Here is the first set of pictures!
Old 11-29-2012, 03:54 PM
  #56
SMKN TA 95's Avatar
As I mentioned above, here are some pictures of the firewall where both the BS3 harness connectors are, along with the nitrous harness. The last picture is of my new COP wiring harness to run the coils.
Old 11-29-2012, 03:55 PM
  #57
SMKN TA 95's Avatar
And last but not least, are the rest of the interior pictures.....
Old 11-29-2012, 05:37 PM
  #58
MUSTANGBRKR02's Avatar
Car looks amazing.
Old 11-29-2012, 08:27 PM
  #59
Mr. French's Avatar
[/QUOTE]
What steering wheel is that? looks badass
Old 11-29-2012, 09:06 PM
  #60
LS1Tech Premium Sponsor
ssvert99's Avatar
There are a few companies out there doing those type of steering wheels, but that particular one is the ultra-light aluminum model from Quartermax.
Quick Reply: Brian Black's X275 TA Build at Midwest Chassis......
