Drag Racing Tech
Spark Plug Gap???
Old Sep 16, 2012 | 11:03 AM
RENE'S RAGE's Avatar
Default Spark Plug Gap???
What should I gap my plugs at?
11.7:1 compression.
Around 25 degrees timing
110 leaded race gas (don't trust pump gas)
TR6 plugs
Track only car.
Old Sep 17, 2012 | 01:44 AM
Wicked94Z's Avatar
.030" or so seems like a good starting point. Tighter ain't bad, I've run .022" in the N/A LT1 and it runs fine.
Old Sep 20, 2012 | 05:35 PM
Anyone else, can someone explain the difference in a narrower gap than a wider gap.
Old Sep 21, 2012 | 06:59 AM
Longbob's Avatar
What ignition system and coil are you using? This makes a difference on the recommended gap settings.
Old Sep 21, 2012 | 05:54 PM
Stock LS1.
Old Sep 21, 2012 | 08:24 PM
Longbob's Avatar
Ok, that is a longer duration ignition system so I would gap them at .035.
Old Sep 21, 2012 | 08:26 PM
Longbob's Avatar
Sorry, I forgot to answer the difference. A shorter duration, but more intensive ignition system like a MSD 7AL2, would be better served with a wider gap like .045.
Old Sep 22, 2012 | 12:25 PM
Thanks!
