Initial shock setting advice needed
So-So track prep.
SA QA1s up front and DA AFCOs rear.
Recommendations would be appreciated.
Also, how would setting change if I went to a bias-ply tire like an ET Street?
Driver's Front 0 Passenger F 0
DR 7 PR 9
Each car is different and requires trial and error to find best settings. If you put it on the lowest setting in the front and car rises too much-raise the settings until it barely comes off the ground.
