Drag Racing Tech
Comp Engineering Roll Bar
Old Sep 24, 2012 | 01:18 AM
Jadedbird's Avatar
Default Comp Engineering Roll Bar
Alright so my times have surpassed the 11.99 so its time for a roll bar
I will be ordering the comp engineering 6 point cage from summit racing along with some kirky sfi padding in a few days
my questions are about this jig notching.. installation.. and painting
is the jig notching a big ordeal? i have a friends father who is a welder for a power plant who will weld it for me.. but as for the jig notching, its simple measure and cut right?
obviously to install ill have to remove all of the interior, but does anyone have the comp engineering style 6 point? i dont think it has the low slung sides.. so is this something i can bend? or will that be again nhra rules to alter a roll bar like that?
last.. how did you paint yours? did you paint it after welding it together and then installed it into the car, or did you install it.. tape everything off and then paint it while it after it was completely installed?
thanks for the help
Old Sep 24, 2012 | 08:39 AM
RamAir95TA's Avatar
Jig notching is EVERYTHING. It amazes me companies offer bars without it. Notching the bars yourself is not for the faint of heart without the proper tools.
Why not go with the Wolfe 6-point bar with the low slung sides, jig-notched? Mine fit perfectly with no problems. And they are a site sponsor, too.
I painted my bar when it was already installed and in the car.
Old Sep 24, 2012 | 08:53 AM
fergymoto's Avatar
You pretty much have to paint it after it is installed. Notching isn't bad if you have a die grinder with a good carbide bit. It would be quicker and easier with a tubing notcher. It all depends if you want to spend the money or do the work yourself to save some.
Old Sep 24, 2012 | 08:58 AM
high impact's Avatar
^^^^^^^What he said ^^^^^^^
I have installed numerous roll bars but never in a 4th gen so take my advice for what it is worth. You don't need a tubing notcher but it will certainly make life a ton easier, fish mouthing the tubing ends with grinder takes a little skill. Installing a roll bar is not for the faint of heart - it will require a decent degree of skill and patience. It will save a ton of heartache if you can get a kit that is pre-notched. I have always painted the bars after install. Follow the rules closely - my local track could almost care less but if you'd ever take your car somewhere else they may care and you want it to be correct with nice welds.
Old Sep 24, 2012 | 10:41 AM
Jadedbird's Avatar
Well id like to get a wolfe bolt in. But i would like to keep it under $500..
But Wolfe is $480 shipped with their offer right now (Mild steel weld in everything standard and jig notched)
Id have to buy a case of busch light for my friends dad, and as for paint, ill probably just spray can it since most will be covered by padding anyways
If i go that route, i could still keep it under $600 and probably get it painted right
Old Sep 24, 2012 | 11:45 AM
HioSSilver's Avatar
Don't be fooled by the notching thinking it will go in easily. You will have to finish fitting it even on the notched end.
Old Sep 24, 2012 | 12:00 PM
zracer323's Avatar
I noticed you said 11.99, NHRA rules don't require a bar until 11.49.
Old Sep 24, 2012 | 04:05 PM
Mighty Whitey's Avatar
^^^ this.
Save your money up and buy a nice rollbar from a company that is known for a well-fitting product. I'm not putting CE down, but there is a multitude of testimonies about the Wolfe 6pt on this board. CE? Not so much..
Old Sep 24, 2012 | 05:47 PM
Jadedbird's Avatar
Well my track kicked me Out saying 11.99.. Which is like 8 or 9 something 1/8th miles
Old Sep 25, 2012 | 09:18 AM
zracer323's Avatar
I believe the 1/8th mile cutoff is 7.35. Bring an NHRA rulebook with you next time if they try to kick you out.
Old Sep 26, 2012 | 12:54 AM
brandonppr's Avatar
If it is an NHRA track then it changed a few years back in the rule book. I would show them the rule book. My local track didn't know it changed until I showed them the book.
IHRA I think is still 11.99
http://www.bremertonraceway.com/2012_NHRA_RuleBook.pdf
Page 66
ROLL BAR
Roll bar mandatory in all cars (including T-tops) running 11.00
(*7.00) to 11.49 (*7.35), in convertibles running 11.00 (*7.00) to
13.49 (*8.25), and in all dune-buggy-type vehicles running 12.00
(*7.50) seconds and slower. Permitted in all cars. See General
Regulations 4:10, 10:6
Old Sep 26, 2012 | 07:58 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
As stated above, if you are attempting a roll bar install yourself, the extra money spent on a good PROVEN product will do wonders. for photos of completed installs so you can make an informed decision. Just like previously said; not knocking Competition Engineering, but make sure you dot the i's before buying.
Derek
Old Sep 27, 2012 | 01:36 PM
Jadedbird's Avatar
I think lll just pony up the money for a wolfe rollbar
Old Sep 28, 2012 | 05:34 AM
RamAir95TA's Avatar
Good plan.
Old Sep 28, 2012 | 11:02 AM
Jadedbird's Avatar
Im just trying to figure how/what color im gonna paint it
Old Sep 29, 2012 | 09:17 AM
Packy's Avatar
They can come powder coated black unless you order it bare and want to do it yourself.
Old Sep 29, 2012 | 12:51 PM
Jadedbird's Avatar
Wolfe does? Well thats super badass
Old Sep 29, 2012 | 08:08 PM
Packy's Avatar
You can always buy a Wolfe bolt-in if it fits your speed requirement. A buddy of mine and I installed one in my garage in about 4-5 hours.
Old Sep 29, 2012 | 08:24 PM
That Wolfe bolt in looks great - what et is a bolt in roll bar good for?
Old Sep 29, 2012 | 09:06 PM
Packy's Avatar
10.00 in the quarter mile, as soon as you go 9.99 or over 135mph technically you need an 8.50 cert, lic, etc.
