Drag Racing Tech
Comp Engineering Roll Bar
Old Sep 29, 2012 | 09:16 PM
high impact's Avatar
You can run 10's and still have a roll bar that can be easily be removed? I like the sound of that! I have always had weld in bars in my previous cars. I don't mean to pirate the op's thread but does the center bar remove easily so that the back seat is accessible for street driving?
Old Sep 30, 2012 | 02:18 AM
Jadedbird's Avatar
I thought the center bar has to be welded? And i plan to be under 10s
Old Sep 30, 2012 | 06:15 AM
Packy's Avatar
Yeah the center has to be welded and if I go faster than 10.00 it won't be by much and my local track won't really care unless I am going 9.50's or lower. I don't see that happening with my little P1SC-1.
Old Sep 30, 2012 | 07:45 AM
HioSSilver's Avatar
That is a good lookin bolt-in bar. Thanks for postin pics Packy!
Old Oct 4, 2012 | 05:21 AM
Packy's Avatar
No problem. Along with that I did some creative weight reduction so when I get finished with the front K-member I will see how much it helped. I mainly needed the bar so my local track will get off my case. They won't let me run either of my vehicles anymore.
Old Oct 4, 2012 | 07:11 AM
HioSSilver's Avatar
Get on it!! Those things are built like a tank, plenty of weight to be found. Especially if you build your own pedestals like I did.
I'm in the same boat. They haven't kicked me out yet but I have had multiple warnings. I would want something I could take out for most of the year.
Old Oct 4, 2012 | 01:01 PM
Jadedbird's Avatar
I wish i knew how to weld
Old Oct 4, 2012 | 01:02 PM
Jadedbird's Avatar
Packy-Do you have pictures of where the back seat mounts are?
Old Oct 5, 2012 | 09:31 AM
Gfleck047's Avatar
The main problems I've had with competition engineering is that nothing fit nice.. we ordered a 6 pt bar for a 76 vette the main hoop was so wide we set it over the car as an exocage. That cage also almost fitin my mustang it was a few inches to short.. I would recommend gettin a Wolfe's or bending one your self
Old Oct 5, 2012 | 07:14 PM
Packy's Avatar
Here is the only pic I have from the back seat area. That was while I was re-installing the carpet and trim before I installed the seats.
Old Oct 27, 2012 | 09:02 AM
a-low's Avatar
Packy- if you wwere to remove the cage would you have to cut it or can it
come out in one piece?
Old Oct 27, 2012 | 09:44 AM
  #32
Packy's Avatar
I can completely unbolt everything if I wanted to but that would take a lot of work. It is not like you can just unbolt it and remove it when you want to. I mean you could do it if you don't mind doing 4-6 hours of work everytime you want to install or remove it. LOL!
