Drag Racing Tech
Lightweight Defrost Setup....
Old Oct 25, 2012 | 01:04 AM
Turnin20s's Avatar
Default Lightweight Defrost Setup....
This winter I plan on removing a few pounds off my car and getting rid of the heater box to get better access to the rear header bolts and spark plugs. I was just going to knock off the engine bay side of the heater box and install a flat plate and leave the heater box on the inside, but after reading Studderin's diet thread I came up with a little bit different idea.
Rather than reuse the stock squirrel cage fan, like Studderin's setup, why not use the Probe heater core and fasten a couple computer fans to the bottom to force the air through the heater core and on to the windshield.
The only problem that I see is that the computer fans don't really push a lot of air (~70 cfm per fan), but they only weigh about 5 ounces each.
What do you guys think? Is the stock squirrel cage fan a better option, or would the computer fans actually work?
Old Oct 25, 2012 | 06:19 AM
RamAir95TA's Avatar
Unfortunately you probably wouldn't know until you installed them. But I can tell you this - the breeze coming off of a computer fan is hardly a fart so I have my doubts.
Old Oct 25, 2012 | 10:36 AM
sweetbmxrider's Avatar
If you are gunna try it, at least move some more air.
http://www.performance-pcs.com/catal...ducts_id=24415
Old Oct 25, 2012 | 01:08 PM
Turnin20s's Avatar
Giving me something to think about. I figured it wouldn't move alot of air, but the fans in the link would and then I would only need one instead of using 2.
I would just hate to have to pull the dash and switch to a setup like Studderin if the computer fans weren't enough. Maybe I'll grab a couple of the fans in the link and see in person how much air they move.
Old Oct 27, 2012 | 02:22 AM
Pony Exp.305's Avatar
I would like to know how those drag using small heater inside..
Old Oct 27, 2012 | 09:02 AM
99french's Avatar
It was super easy for me. I called summit and ordered their little heater box that has two holes. Now I have defrost and one for the wife's feet. It weighs either 9 or 11 pounds and that's all the brackets and wiring. Hooked it up to my factory controls and it's super stealth. Plus I went to menards to get a sheet of aluminum for the delete plate and made it myself.
Old Oct 27, 2012 | 11:13 AM
Turnin20s's Avatar
What??
I have considered that, but it costs money haha. Probe heater core is ~$40, the fan could be free if I reuse the stock one and it will weigh less than 11#s I hope, hopefully closer to 6#s. I'm going to also remove the HVAC controls and hook the fan to a switch thats hidden in the center console.
Old Oct 27, 2012 | 06:07 PM
studderin's Avatar
BTW I just used the probe heater core because I had it laying around. I and alot of other GTP I worked on we used them as a heat exchanger bolted under the supercharger. From the IC kit ZZP sells, you could use any heater core, maybe even your stock one?
Old Oct 28, 2012 | 01:20 AM
Turnin20s's Avatar
I hear ya on that, but the straight outlets and a local hook-up at the parts stores makes a different heater core a cheap choice. and my heater core has 125k miles on it so its a little insurance against leaks.
Thanks for posting up the great details on your diet thread, I have been lurking for a while and gathering ideas
