Cars on trailers
Specifications:
GVWR: 10,000 lbs.
Bed Length: 18’
Width: 82” Inside / 102” Overall
Deck Height: 20" (16" at Rear)
Empty Weight: 2,255 lbs.
Standard Features:
5" Channel Tongue
5" Channel Main Frame Rails
4" Channel Lower Frame
Full Diamond Plate Steel Deck
Removable Fenders
Stake Pockets (6)
Weld-on D-Rings (4)
5' Punched Metal Slide-Out Ramps
2-5/16" A-Frame Coupler
5k Top Wind Jack
7-Way RV Plug
Sealed Wiring Harness
Breakaway Switch
Charge Wire w/ Circuit Breaker
Push to Test Battery
LED Rubber Mounted Lights
ALKO Ultra Lube Axles
Electric Brakes
White Eight-Spoke Wheels
Bias Ply Tires
http://www.cbrperformanceproducts.co.../toe_hooks.htm
I would tend to agree with this. Although in theory the idea is good traveling down the road, especially on a long trip, puts a lot of strain and pull on the straps and that bracket looks like something that may fail over time. I know it can be a PITA to go up over the axle tubes but that seems like it would be worth the effort every time.
Scott
