RPM Transmissions Track Rental October 24th 2012
Hi everyone. I just wanted to invite you all to our annual RPM Trasmission track rental. It will be at Muncie Dragway on October 24th 2012. We are all meeting here at the shop at 8am. The address is 1426 W. 53rd St. Anderson, IN 46013. All cars are welcome. You don't need to be an RPM Transmissions customer. The track prep should be good. This is just a day to come out and run the bag off of your car. There will be no bracket racing or any BS like that. Grudge racing is recommended Please make sure your car is up to the task of racing and isn't going to ruin the track with leaks or broken parts. This will keep the day going smooth and insure we can all make as many passes as we want. Tech will be fairly loose. They only ask that you wear a helmate if your car requires you to and no shorts or flipflops. This event is on a Wednesday so there will be additional test and tune from 6pm-10pm. It will be $20.00 to stay for the test and tune.
If you have any questions post up, shoot me a PM, Email or give me a call at 1-800-406-1109
Hope everyone can make it out!
https://maps.google.com/maps?q=munci...h&z=16&iwloc=A
LS1TECH Sponsor
Wow, sounds good. I'll try to bring the Formula and drag Bob along.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
