How to make sure I run an 11?
I would like to run an 11 without gearing my car too much towards drag racing and preferably keeping my 10bolt. The the old owner of my h/c/i ran a low 10 but his car was set up for straight drag racing.
I now have a 404 ls2 w/ fast 102/102, ported l92s, big cam, full boltons. M6, 3.42s, 275 nitto drag radials. Little bit of weight reduction.
I dont have nitrous hooked up at the moment.
I assume i should have the power and reasonable traction to pull off the goal of an 11second pass but is there anything else i should try thats cheap/easy to guarantee the goal.
I never got a good 60 footer on street tires so hopefully the nittos help.
I will pull the swaybar off and knock a little weight off, hopefully will report back in spring with an 11.
I've run several 11 sec passes at 111mph and my car is not setup with drag suspension at all. It leaves flat as a board. Just put a badass tire on it, heat it up well, and go on a night where they actually have track prep. I can't imagine running a 12 at 128 with anything less than a 2.6 60ft. Figure out how to make the car leave.
