Launches, bogs or spins Video Inside
I started with the RPM switch at 3000 rpm, launched at 3500 rpm and spun through 1st with no bogging. 2.01 60 ft and I lifted 2 times in first and once in 2nd to get it to hook up.
I bumped the rpm switch up to 4000 rpm, Launched at 3000 rpm. Jumped off the line and bogged. (In video,far lane, not me that had the backfire).
So I lowered it back down to 3500 rpm, launched at 3200 rpm. Same thing. jumped, bogged.
Lowered it back down to 3200 rpm, launched at 3200 rpm. Jumped off the line, bogged.
No more time for cool down before the track closed. And I killed a pilot bearing on the last run.
You can actually see the n2o kick in in the video past the 60' mark. It's coming on at the right rpm that I set.
Any ideas?
I really want to keep it a M6, but now I don't know.
Trying to hook on DR's is more expensive but can be done. You can change up the suspension with adjustable shocks in the rear and front. You would want to set the rears in the middle setting and tighten the rear until it doesn't hook any more then go back down. You can also try slipping the clutch some so you won't bog and get out of the hole easier.
The clutch. You need some adj shocks and it doesn't sound like you have the patience to get a DR to work. Get some bias ply tires. It takes alot of the right
Parts and you gotta learn how to launch a M6 car. You can always go the
Auto route, but I like driving my car.
ya, it takes some time, practisng on the street helps, its even harder at the track, harder with a car next to you. There a lot better clutch out there then stocks, not just one with alot of holding power thats a on /off switch. anything is better then the stock shocks. if you want to keep running the DR you gona need some good duals front and rear, strange at the lest.
It's not that I haven't tried to slip it. It's a worse 60' when I did. But that was before the n2o . I am saving for a 9" as well.
If i could get enough momentum until my spray kicks in my 60' would come down.
I'm really trying to keep it a M6 . I like the shifting. 4.10's would get my rpms up quicker.
I'm not thinking 1.40 60'. I'm a realist. A 1.70 would be awesome right now. .3 in the first 60' would bring my et way down.
Sorry for all the questions. Nobody else that i know has the M6. They're killing me off the line and et wise but I'm trapping way more than they are.
They are always going to E.T. better than you because they are getting their 60 foot unlike you and because their 60 is better their mph is lower. You are taking longer to cover 1320ft compared to them is the reason why you mph is more. Watch what happens when you get that 60ft down.
