Drag Racing Tech
Drag wheel center caps
Old Nov 8, 2012 | 09:31 AM
Jenson's Avatar
Default Drag wheel center caps
So I hate the 4x4 look of the weld center caps. I have a flush design that Im going to make for mine. Just curious if there's interest in them? Or am I the only one that cares? I have one design that's like the stock ones but shorter, and another that uses an o-ring and goes on like stock caps to clear bigger axles and what not. I can sell them for ~$40 and $80 respectively, cnc'd from 6061 or in my case, black plastic
Old Nov 8, 2012 | 12:36 PM
xpndbl3's Avatar
how are you making them flat when the hubs usually stick out of the rims in the front?
Old Nov 8, 2012 | 02:17 PM
Jenson's Avatar
They do?!? The hub centric ring on all the ones Ive owned/own is 3/16" to a 1/4" thick. The wheel is 3/4" there, plus we have to run a 1/4" spacer up front too.
Old Nov 8, 2012 | 03:03 PM
a98ws6's Avatar
Aftermarket brakes will stick out.
Ive seen some billet caps on Yellowbullet that somebody makes.
Whatever happened to the carbon fiber hood/side grills you made? Still wanted hood grills.
Old Nov 8, 2012 | 04:35 PM
Jenson's Avatar
I had so many issues with carbon suppliers they would be to expensive. They wanted to charge me $100 for a set. I could get a buddy to do them now, but he's slow, and wants $65 a set.
For sure aftermarket will. I thought he meant stock.
