Drag Racing Tech
Budget Drag Setup!
Old Dec 26, 2012 | 08:28 PM
unioncarpenter84's Avatar
Default Budget Drag Setup!
ok guys ive been doin my homework decided not to lower the car.
did decide to make it more for the track right now i have agx rear shocks with stock springs and factory 120k mile stock struts and springs.
itlll lift the front wheel just enough to see it.
i kno that my set up is wore out
so i decided to go with 70/30 Lakewood drag shocks and the 50/50 Lakewood Drag shocks for the rear..
But unsure to get v6 springs or just to get my factory v8 springs.
what do u guys suggest the v8 springs or the v6
those drag shocks should be alright for the street right??
Old Dec 26, 2012 | 09:12 PM
WhiteLTone's Avatar
i run v6 springs in the rear of my car, i like them better than the cut factory springs i had before. if you do the bumpstop mod it'll lower it slightly too.
Old Dec 27, 2012 | 10:16 AM
Blackpanther99's Avatar
V6 springs will be better than V8s no doubt. The drag shocks you have listed should be fine, you can remove the bumpstops to have a lower stance look.
Old Dec 27, 2012 | 05:33 PM
how do those v6 springs do on the street?
Old Dec 27, 2012 | 05:34 PM
v6 all the way around?
Old Dec 27, 2012 | 05:54 PM
heres a video http://s1214.beta.photobucket.com/us...e9f29.mp4.html
Old Dec 28, 2012 | 11:54 AM
Tan327's Avatar
I run v6 springs all around, my only suspension mod except for rear drag shocks and relocation brackets, have pulled a 1.53 60' cam only, works okay for a budget setup.
Old Jan 1, 2013 | 07:28 AM
Ls7colorado's Avatar
video not found, shouldnt you be in the 11's with your setup and a 1.67 60?
Old Jan 1, 2013 | 09:36 AM
Old Jan 1, 2013 | 09:38 AM
ya ur right i gotta get the car dyno tuned and should be in the elevens.
what do u think bout my launch?
i just bought 1le springs i just need a set up shocks and struts what do u recommend
Old Jan 1, 2013 | 12:48 PM
Slowhawk's Avatar
LS1Tech Sponsor
For a budget I ran 100k mile stock shocks/springs with a BMR drag bar and removed front bar. Hit 1.50 60's on my nittoe 315's on 17" rims. Awesome bracket racing setup.
Old Jan 1, 2013 | 01:00 PM
ya im running without the front sway bar
going to be running with 315s
