Drag Racing Tech
Welds?
Old Apr 16, 2004 | 03:33 AM
1QwickLT1's Avatar
Default Welds?
whats up guys, whats the rim size u guys have on ur rims??? Like what backspacing etc. I was looking into getting some weld draglights for the track, but don;t know what size to look for. THanks, David.
Old Apr 16, 2004 | 08:28 AM
Humanoid's Avatar
This is some text I saved as a guide when I am ready to by my Rims. This post was from Nineball.
Weld Draglites or Prostars are your best bet.
Tons of us run 15s on the front and rear. You will have to grind the front face of the rear calipers to make them fit. Takes about 15 minutes per side with a disk grinder. Also need 5/16" spacers behind each wheel.
15x3.5" fronts with 1.75" backspacing
15x10" rears with 7.5" backspacing
Fronts are $105-120 each
Rears are $169-180 each
Not sure if any of our sponsors carry these, but most of us get them from Jegs or Summit Racing.
your lug pattern is 5 lug x 4.75" bolt-circle
Old Apr 16, 2004 | 08:44 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
These are the sizes I run. 15x3.5" fronts with 1.75" backspacing 15x10" rears with 7.5" backspacing.
Coach
Old Apr 16, 2004 | 04:09 PM
SUX2BU's Avatar
i would advise getting longer studs if you run a spacer, too. (wheels tend to fall off with spacers and stock lugs). or do what i did grind the HEEL out of your calipers and run with no spacers all around.
Old Apr 16, 2004 | 07:07 PM
1QwickLT1's Avatar
THanks for all your input fellas, but i dont want to grind the **** outta my rear calipers too much because i will only use the welds for the track, and when i have my rims on, i dont want it to look 2 bad. Thanks again.
Old Oct 5, 2005 | 07:53 AM
Jersey_TA's Avatar
Is that the same with a ls1? sorry newb question
Old Oct 5, 2005 | 01:05 PM
_HAVOC_'s Avatar
yes..
Old Oct 9, 2005 | 10:54 AM
Anonymous's Avatar
10 second playa
So then 7.5" of back spacing is not ideal.
Is 7" Ideal? BTW I know the regular Welds don't come in that backspacing,
But, just to know, what is ideal?
