Cage install questions
The helpful thing I did find is using a hole saw to drop the bars down and then put the plate over it. So do you tack them and form them in place first, grind the welds and then cut the hole to drop them to weld them all up? Along with this is the headliner. I'd like to have it in for a full interior look, but I also don't want it to catch on fire. Any tips there?
Also I've looked at a ton of install pictures and was wondering does it matter where the bar contacts the plate? It seems like some of the certified cages had the plates welded in a easier spot and the bar contacts on far corner. I would think that you would want the bar in the center of the plate. Or is there a rule that specifies that it has to be x" from the edge of the plate?
Would someone be able to give a quick overview of the install process, ie when to weld the plates and the order of the bars installed?
Beaudacious
Thanks
also when we did mine we tacked everything in the car then broke it into 2 large pieces and completely weled them outside of the car. Then stuck them back in the car and welded them together and to the floor plates.
Also I had the headliner and all interior out and put it back in after the cage was done
Also, in the location that I chose and the more popular one, I don't see how it's possible to cut a hole there and drop the hoop down. The reason that I want it on the higher portion is because it's about 4" from the furthest spot on my seat.
