Drag Racing Tech
Density Altitude(DA)?
Old Apr 17, 2004 | 03:33 PM
02WS6#519's Avatar
Question Density Altitude(DA)?
How do you calculate for DA?
Thanks
Ever
Old Apr 17, 2004 | 03:40 PM
JNorris's Avatar
Moderator
The link below will do it for you.
http://wahiduddin.net/calc/calc_da.htm
This link will provide you with the weather conditions by zip code. Just input your zip.
http://www.weatherunderground.com/cg...st?query=36117
You will also need to get the elevation of the track you run at.
John
Old Apr 17, 2004 | 03:50 PM
02WS6#519's Avatar
I just found out that the DA for the day I ran was 6500ft. I ran a 13.4@107mph before the H/C. Do I use the altitude correction factors for DA or actual elevation? Which is 4500ft.
Thanks
Ever
Old Apr 17, 2004 | 07:03 PM
kp's Avatar
kp
you would use your DA to figure the correction if you are trying to see what your car runs at sea level. This page will save a couple steps if you know the weather/track elevation:
http://www.modulardepot.com/density.php
Old Apr 17, 2004 | 08:10 PM
02WS6#519's Avatar
So my 13.4@107mph run corrected is a 12.2@116mph. Nice!
Thanks
Ever
