Cutting Up Radiator Support Metal
I have been wanting to cut out the front of my car so I can eventually stand up the radiator and cut some weight right now. I have an LT1 car and am in the process of fitting an LS1 lid and have to cut it up to make it fit anyway.
So my plan is to cut the whole section out and weld in a tube across the front and box in the sides. Then I can make some mounts for the lid and mount it a little lower than it is currently.
I also plan on cutting out the lower radiator support and building a tubular mount that also mounts the air dam since my car is a street car. But in order to do the lower mount I need to purchase a tubing bender.
So what have you guys done on your cars? I have seen some pics from some turbo cars, but not too many still using the rad in the stock location.
I'm going to try to start cutting this weekend, but I need to bring the welder from my dads shop before I can really do anything.
If anyone has pics or some insite I would appreciate it
An ls1 lid will not clear the stock hood unless the radiator is laid back, I don't see how you could make an ls1 lid clear at all with the radiator stood up. Look at the above pics, nobody is running a lid with a stood up radiator.
Love your cutting the weight off the front thread btw
Thanks man, I'll try to stay motivated on the weight removal thread. It's been hard with my new schedule at work
was 3060 last year with an iron block. Since then ive gutted doors all factory wiring added lightweight steering column and door panels. And had eric at mwc do the front end work. I hope its 2900. I have a build thread in n20 section. I dont wanna hijack your thread.
