looking to buy front/rear drag shocks
i dont want to spend alot of money .. what would you suggest ?.... i'm leaning towards strange single adjustables , i have these on my mustang and they work really well .. and what front coilover spring rate ?
Im fixing to order the same thing this week. Strange SA up front with 275lb springs (drag specific but my front end is light) and Strange SA 10 ways for a fox body out back. 300lb springs seem to be the norm for a street car.
I have the strange singles, they work well on my car and actually ride nice on the street. Make sure you get a couple spanner wrenches. I personally wouldn't use the bearing kit, they help the first time you set the ride height but will rust real bad if you street drive the car.
super budget I would do that strange single on the front R, ($150 each) and re use you stock coil and spring. (cut the lower washer to fit) bearing kit like $25
rear the cheap summit racing/destech? white 3ways. or the comp/eng. 3 ways are like $30-40 a set for a 3rd gen (little long for out cars but bolt right in) set them at 50/50. alot of guys have gone fast with that. I went 10.6s cam only on etdrags. 1.43 best no front sway, good rear, spool, gears, any rearend, is a good buget setup.
But with that said, going faster with DR, good DA shocks were worth the money 1.44 on 275s
LS1Tech Premium Sponsor
i have a budget of $2500.00 for suspension .. that is going to include BMR parts , tubular -K member , upper and lower control arms , torque arm, torque arm relocation , sub frame conn, front + rear shocks, front coilover springs .. i allready have rear lowers and panhard bar
I can get you setup with the entire package for well under 2500.00 no problem. Highest quality parts, lightest weight, and proven to work. Give me a call and we can go over all the fine details.
my new moser 12 bolt has adjustable LCA brackets welded on so i'm allset there , i already have BMR LCA's and adjustable panhard, what do you mean by "trackbar"? the bar above the panhard bar ?
