Drag Racing Tech
Weighed my car today (Race weight)
Old 03-12-2013, 06:39 PM
MFJ
MFJ's Avatar
Default Weighed my car today (Race weight)
The car is 3320 lbs race weight but that was with 3/8 of a tank of gas and a full 10 lb bottle of N2O (35lbs). I'm 180lbs so it'll be 3500 lbs with me in it.
I really need to get the weight down on the car. I've removed a lot of stuff to save weight. I don't know how much the Trans Am weighed from the factory so I don't really know how much I've taken off.
Removed: No rear seats, true duals dumped at the axle, SS headers, no passenger seat, brackets removed, seat belts removed, spare removed, AIR delete no EGR, no washer fluid, T-top holders removed, rear speakers removed, floor mats removed, lightweight flywheel. nothing in the compartments either.
My race wheels are next and a Smoothie Q hood to replace the stock one. Still need aftermarket brakes too. More weight reduction there.
I heard of one guy getting down to 3150 lbs and still keeping his a/c!! I really would like to keep my a/c and heat.
Old 03-12-2013, 07:25 PM
01 Vert ws6's Avatar
did you take out the bumper reinforcements
Old 03-12-2013, 07:51 PM
senicalj4579's Avatar
Good job. Race weight means with YOU in the car though. So 3500lbs would be the race weight.
If you want a great weight reduction at a great price check out my bumper supports from MWC.
https://ls1tech.com/forums/drag-raci...-supports.html
Old 03-12-2013, 08:03 PM
Baconz28's Avatar
What he said ^^^ about those bumper supports. It's hard to beat that price at only 150 a piece. And we all know weight off the nose of car is a good thing. Car now is at a good race weight but if you want lighter may be time to invest in tubular suspension parts and ditch the power steering for a lighter Manuel setup.
Old 03-12-2013, 08:29 PM
krissoto's Avatar
My WS6 weighed 3720 without me in it and 1/2 tank of gas.
Old 03-12-2013, 09:53 PM
adamantium's Avatar
Skip the MWC bumper support. If you're on a budget get a hole saw set and get to town on the bumper supports. Ive seen several people cut out 10+ lbs off the stock supports. I completely removed my rear support and im going to make some brackets to support the bottom of the bumper for piece of mind. Can't wait to install my MWC k-member though.
Old 03-13-2013, 06:26 AM
MFJ
MFJ's Avatar
I haven't taken the bumpers off yet to get to all the 5 mph crash crap yet. But I like the look of those bumper supports. 30 lbs is a lot.
Should get some nose weight off with the VFN hood, brakes and the bumper supports. This is a heavy *** car to be plastic and fiberglass. The monsoon stuff is coming out this weekend and I'm going to make a quick disconnect for the radio so I can just pop it in and out. Like the old school Blaupunkt!!
Is there anything to do to reduce the weight around the t-top area? Like inserts instead of real t-tops?
Does anyone know how much the T/A's weighed from the factory? This one had every option available it looks like.
Old 03-13-2013, 12:30 PM
bufmatmuslepants's Avatar
My 155lb brother rolled across the scales at 3710 in his 00 m6 fully loaded ws6. My 170lb self rolled across at 3170 in my 94 iron lt1 m6 hardtop Z with a very heavy 9" with full adjustable rear suspension and zero $$$ in weight savings parts, just free ****, and no cutting.
Old 03-13-2013, 12:51 PM
Stroked96Bowtie's Avatar
Will likley need to start coming out of pocket for light wieght components, kmem, a-arms, chromoly rear sus, etc. I had my 96 camaro down to 3260 with no driver: no ac, FULL interior and dash, no front bumper support. I had all tubular frontend and chomoly suspension.
Old 03-13-2013, 01:39 PM
HioSSilver's Avatar
LS1Tech 20 Year Member
Damn ya'll have some heavy cars. When in drag form (big/littles !front bar) I can be a little less than 3000 depending on fuel load. I still have all creature comforts, full interior, all but 2 spots of sound deadening(removed the t-top well deadening and under dash deadening). DDing it with my 18's, front bar and normal crap you haul around I'm at about 3050....well may be a little less now
my weights are car only weights.
Old 03-13-2013, 02:06 PM
adamantium's Avatar
Heres a pic a member on here (92notch) sent me of what he did to his front support.
Old 03-13-2013, 02:07 PM
MFJ
MFJ's Avatar
That's what I'm talking about right there. That's what I want to do. How?? If you don't mind me asking.
Old 03-13-2013, 04:09 PM
marksboy7's Avatar
Well for one, the camaro's are generally lighter than the firebirds from the factory in the first place so that makes a considerable difference.
Old 03-13-2013, 04:33 PM
HioSSilver's Avatar
Kinda like the pic above. 92notch and I are buds. He has taken my Q on some stuff. It's easy to get these cars to 3200 or so. That happens in the course of careful modding. To get where I am is ALOT of attention to detail.....and ALOT of whittling. I still have not done anything to the main chassis of my car though. Just pieces I can unbolt lighten and bolt back on. Of course there are lots of little things that go away in the process also.
ex. I took 3.5 lb out of my hood hinges, 9lb out of the rear bumper, the front bumper is similar to above, 1lb out of the coil pack brackets......and on and on and on...lol
Done right all these pieces remain solid parts and and it ends up adding up big time. I may actually be able to get it to the low 2900's and still be a complete car. It's just getting the time to do it.
Old 03-13-2013, 04:46 PM
adamantium's Avatar
Not really, it usually depends on what model and options are being compared. Both type of cars with the exact same options (seats, hardtop, wheels, year etc...) are within a couple lbs from eachother. Obviously a low optioned z28 and a full optioned T/A are a good amount of weight difference but that is apples to oranges.
Ive asked HIO and 92notch a **** load of questions and ive learned alot about where you can get weight out of these cars from.
Lightweight battery (hio has a 4lb battery) bucket seats (12lbs each) carbon fiber hood (still keeping functioning hood latch etc..) no and or holw sawed bumper supports, tubular kmember or holesawed stock k-member, light weight wheels and tires, Light weight clutch setup (mini twin disc or tripple disc will drop close to 40lbs off the driveline), lightweight UDP, No spare and jack, single dumped ORY or dumped true duals, no traction control etc, a bunch more **** you can do But those are th major ones. I have BS done to my car and the other day i did the math and i should be over 100lbs off of the car and most of which was just removing and replacing ****.
Check out member studerin's build thread its super detailed and he has weight figures for everything he removes, gives you alot of ideas.
https://ls1tech.com/forums/drag-raci...itch-diet.html
This thread has weight figures for ALOT of **** aswell.
https://ls1tech.com/forums/drag-raci...y-updated.html
Old 03-14-2013, 05:47 AM
MFJ
MFJ's Avatar
That's good information. Thanks guys. Gonna start pulling more wieght this weekend.
Old 03-20-2013, 09:00 AM
eteller's Avatar
I have yet to take the nose off my 2000 T/A dd. I assume if you remove the bumper supports completely you would need the MWC support right? Did 92notch cut the larger holes as well?
Old 03-20-2013, 09:12 AM
Grr
Grr's Avatar
My Camaro is 3380 race weight with a 99% full tank, I'm 175lbs. Have all sound deadening, ac, cruise, full interior but no rear seats.
Basically a k member, lexan rear window, and no bumper supports, haven't really cut anything off the car yet
Old 03-20-2013, 10:00 AM
87silverbullet's Avatar
^^^^truth.
I wouldn't say couple of lbs. The OP has a ws6 which was the heaviest f body and he stated with the weight reduction he has done he is at 3320. I have a 2001 SS Camaro and with the little weight reduction I have done is the same as the OP except for the back seats and my car was scaled at 3425. 105lbs is a decent chunk of weight.
I'm getting ready to replace the k member and the front bumper support so I can get the car down below the 3400 mark. I would like to get to 3400 with me in it but that is going to take some work. I'm 220lbs. I think it would be easier to just hire a lightweight driver LOL!
Quick Reply: Weighed my car today (Race weight)
