When are beadlock wheels required or recommended
I'm just curious as to when beadlocks are required. Also is there a recommendation on hp or tq level that a person should use them? Thanks
I would think beadlocks would become a viable option at the 1300-1500 h.p. range. Most cars (actual door cars) woudnt have the power to necessitate it. If your spinning a tire on a rim, you can always use screws to help.
I would think unless your appraoching pro stock/ pro mod type hp, then you should be good to go with a conventional drag racing setup.
Best of luck
Best of luck
Best of luck
Best of luck
It's debated whether or not screwing a drag radial is 'safe'
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
It's a debatable thing. I know an outlaw drag radial racer going 4.40s in the 1/8 on non beadlock non tire screwed wheels (they glue them to the rim I believe). It can make life easier on the stretching and changing of tires though...
That doesn't mean anything if you don't know the wheel width. 315's are a little more forgiving than a stretched 275. We glued the 315s on a 12" wheel and were fine, then went to the 12" 275 combo and it as trying to pull the bead off the wheel.
7 Second Club
1 Post
Which is why I said it's a debatable thing! You can't just blindly say "If you run 10s on slicks you must screw your rims" because it doesn't apply to every case. Once he mentioned the horsepower level and slicks size, did you see my answer change?
You are nearing the need for them. As someone else stated, prostock ran rim screws up until 12-15 years ago, but they are several hundred pounds lighter than you. My dragster has 33.5x16x15 slicks on 15x15 wheels with rim screws. It only weighs around 1600lbs tho. Regardless, NHRA requires them at 210ish mph so I have to stay under that until I can afford the beadlocks. You might look into liners like the tafc guys run. I think the will work with a regular wheel, but you would want wheels that haven't been drilled for screws. The liners use a second valve stem and act like a short inner tube that applies pressure against the beads from the inside. Then you still adjust your tire pressure accordingly and retain some sidewall flex.
Well I contact nhra and as far as rules 6.50 or quicker and 210 mph or faster. So I just went with a 15.1 sfi weld 2.0 wheel. Save me a chunk of money for other items. Haha
