weight reduction whores please step in
as far as wiring, i really dont feel like re-wiring the entire car, but then again i dont have any speakers, heater, a/c, ect. all of the wiring running down the passenger side seems to be stereo and alarm, is it possible to just cut each individual wire then cap it, or will this cause issues? i know this would be extremely ghetto, but would it would without a down fall?
lol. so i guess that means i can do all of the above without any issues? is it easier to cut out this big bracket or cut each spot weld? some of them seem hard to get. and what's the easiest way to remove that white glue stuff, i imagine there are spot welds back there also... clean dig all the seam sealer foam out so you can see the ends off all the tabs on it good. And I like to have a sand disc (smaller the better) so I can buzz the paint off flat, over were you think the spot welds are. Then you can see them center of them better. use the paint so show the low spots. center punch or get a small 3/16 -1/8th stiff stubby drill (center cutting) or a center drill and just drill the center of the spot weld the 1st layer, use that hole as a guild for the spot weld cutter, if you have the spring loaded center style. And with the little starter hole you can angle the hole saw better in the spot weld in in a corner or on a bump and keep it there without it wondering.
Dill the easy ones off a tab to get it loose, then you can pry a little on that. you can bend the rest a little carfully to get to them better and not damage anything, thats can help. And you don't wlays have to drill it 100%, get a stiff putty knife and you can pound it under the layers and get them to pop somtimes if you cant drill it 100% square, or its a doubled weld, or you drilled it off a little. But the metal in thin on the curve of the wheel tub so it will tear out easy. Your probably gona have to weld some of the holes up anyway. You can drill them right out on the middle panel in the fender were the speakers are, your just have the holes ther, but thats the easiest ones to get to and drill out clean. the others the tire is back there. hahaha
LOL
