Drag Racing Tech
Help: Drag racing tires
Old Apr 17, 2013 | 05:46 PM
Cra-Z Larry's Avatar
Well you got the internal trans parts down now how about the converter?? Rim size does matter because 16s have limited tire sizes! Best bet would be to get 15" or 17" rims, more tire sizes available. Is this a DD or just a weekend car?
Old Apr 17, 2013 | 06:40 PM
SuperSlow02's Avatar
Originally Posted by Colesitzy
I know its not making more than 330HP with this tune. Can I ask why you prefer MT over Nitto. Like I said I haven't raced anything this legit before and I just want a third party opinion .
10/10 people would pick MT over nitto, there isn't a comparison. A nitto is a great street tire that can work as a DR(most seem to have limited success) a MT is a drag radial that can be used as a street tire....
As I said, I would never consider a nitto unless I was on 18s or something.
As a few others asked, how much street/track will it see
Old Apr 17, 2013 | 07:13 PM
2birdJosh's Avatar
Will a MT break my stock 10 bolt with 383 rwhp? 2000 T A cam and exhaust ls1
Old Apr 17, 2013 | 07:32 PM
Colesitzy's Avatar
It's my DD, I'm planing on getting 17s
Old Apr 17, 2013 | 08:24 PM
6speed yes....auto probably not, but wouldn't bet money on it
Old Apr 17, 2013 | 08:25 PM
Put a MT on the 16s and run a regular street tire on the 17s . Mickeys won't last long on a DD
Old Apr 17, 2013 | 09:03 PM
2birdJosh's Avatar
It is a six speed. would the nitto break the 10 bolt to. I know I need a rearend but trying to get better traction for now it is out of control! next summer will have better rearend just spent alot on exhaust tune and cam and all that goes with
Old Apr 17, 2013 | 11:34 PM
A 6 speed will snap a 10 bolt with street tires...if you rely on the car, try not to launch it or power shift hard...I went through 3 10 bolts when my was a 6 speed
Old Apr 18, 2013 | 09:07 AM
Colesitzy's Avatar
Do you think Nitto's would break on a 330hp 4A? They would last longer right?
Old Apr 18, 2013 | 09:13 AM
What do you mean by "break"?
Old Apr 18, 2013 | 10:05 AM
krissoto's Avatar
A 10 bolt rear can break with regular street tires, putting any sort of power to them can destroy them, just more so with a 6spd than an auto. I had great sucess with my 10 bolt being able to spray 150 outta the hole on a 325/50. Every car/rear is going to be different. If your gonna beat on it, be prepared for stuff to break. Its just how it goes
Old Apr 18, 2013 | 11:04 AM
  #32
2birdJosh's Avatar
Thanks guys for info. I understand things break all the time. I have had 68 firebird for 20 years and trans am for 7 years. will take advice from super slow and be careful but do you think traction would be better with nittos or just deal with what I have. thanks potenza street tire what i got
Old Apr 18, 2013 | 11:48 AM
  #33
Colesitzy's Avatar
Sorry I though thought "break" meant spin on the line, but will they spin on the line? I'd like it if I could at least drive on my radials some of the time, cause I plan on putting them on nice rims. The main reason I'm getting them is because the car has Firestone Firehawks on it and it losses traction when it upshifts sometimes. And its not like I'm planing to add a turbo or forced induction any time soon.
Old Apr 18, 2013 | 01:14 PM
  #34
Personally I've went low 1.9x 60ft in pure street tires. Idk if anyone has had consistant luck with a nitto. IMO there breakage level would be close to the same with those tires. But I wouldn't put alot of faith in Nittos solving traction issues
Old Apr 18, 2013 | 01:17 PM
  #35
They will be better then the FFs but no where near as good as a real DR. If 2 sets of wheels is an option, I'd hold out for MTs. There aren't any certainties from car to car. You might have decent luck with the Nittos or roll them off halfway down the track.
So to sum it up. MT= sure proven traction/low life
Nitto=iffy traction/ long life.
Old Apr 18, 2013 | 02:01 PM
  #36
roninsonic's Avatar
I hooked at the track with my current setup with Nittos at 18#... They liked heat and launching stalled on the footbrake.
Old Apr 18, 2013 | 05:44 PM
  #37
badamn's Avatar
the MTs' are probably stickier than the nittos and hoosiers are stickier than that but i had problems hooking with even those.A 400 HP M6.I'm really a rookie when it comes to the track though.
Old Apr 18, 2013 | 11:19 PM
  #38
Colesitzy's Avatar
Ok, thank you I think I know what I'm going to do now.
