Drag Racing Tech
manual steering on street
Old Apr 28, 2013 | 12:41 PM
trik396's Avatar
Default manual steering on street
My car is not a DD. Only nice weekend rides. Any benefit or hinderance on spirited street driving?
Old Apr 28, 2013 | 05:14 PM
93camaro_zzz's Avatar
Benefit? Lighter, more engine bay room, and a slight bit more hp since you don't have to turn the pump.
Hinerance? Only one I can think of is it is a little bit of work to turn 275 street tires from lock to lock when you are at a dead stop. Not bad at all though IMO. I am very glad I switched to manual steering in my car.
Old Apr 28, 2013 | 08:22 PM
trik396's Avatar
Can you recommennd what manual setup is best for my UMI k member? All I see is BMR's which is fine but are there others?
Old Apr 28, 2013 | 08:46 PM
trans2000am's Avatar
midwest or burkhart i have burkhart and bolted right in no welding etc
Old Apr 28, 2013 | 09:00 PM
Ed Wright's Avatar
9-Second Club
I have MadMan Racing's manual rack. Works great. Had it for six years or so now.
Old Apr 28, 2013 | 09:31 PM
Kingsize's Avatar
More benefits than hindrances IMO. Do it and don't look back, you will never miss it.
Old Apr 28, 2013 | 09:39 PM
a-low's Avatar
I got one from the rack doctor. Havent installed it yet though.
Old Apr 29, 2013 | 08:46 AM
Zmg00camaross's Avatar
I like my manual rack, all my components are from MWC, I had to build my steering shaft but my setup is a little different.
Old Apr 29, 2013 | 08:33 PM
Yeah mine is a madman rack as well. Had a little bit of a dilemna getting the correct steering shaft (I bought mine used), but madman sent me one straight over quickly to solve my problem. Now everything works great!
Old Apr 29, 2013 | 08:54 PM
lemons12's Avatar
How easy does it turn with skinnies on the front?
Old Apr 29, 2013 | 10:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've run a Madman rack, and on a later car a looped stock rack both with skinnies.
They both drove great with skinnies. But with stock front wheels and tires the latter is brutal.
Old Apr 29, 2013 | 10:42 PM
2 Stroke Racer's Avatar
I have the Bmr k-member with the flaming river rack.
With skinnies it's really not much more effort unless your
Almost stopped and making a really tight turn. It seems
More stable at high speeds to me.
Old May 3, 2013 | 03:39 PM
flyinZ's Avatar
Subscribing...
Old May 3, 2013 | 06:42 PM
BassProCamaro97's Avatar
I have the BMR & flaming river combo and don't be fooled the difference b/w a power rack and a manual rack is night and day. It's not impossible by any means but you have to use some muscle on a sharper turn or parking.
With that said I love the simplicity and the clean look. I'd never go back to a power steering setup in this car.
~Jim~
Old May 3, 2013 | 07:23 PM
~Jim~
Since skinnies are usually on my car, I will say this: Going from a stock 10 bolt to a 9 inch with a spool affected my turning worse than going from power steering to manual.
Old May 3, 2013 | 07:33 PM
LongIsland63SS409's Avatar
+2 have not installed it yet.
Will be running skinnys only.
Mike
Old May 3, 2013 | 07:56 PM
Iceman02's Avatar
^^This.
I'm running a Spohn front K with flaming river rack, and Mickey thompson sportsman pro skinnies in front. The steering is fine, and more stable at high speeds than power steering. I had 275/40s on the front before with the drag radial setup, and it was a bear to turn. If you are putting skinnies on, it'll be fine.
Old May 4, 2013 | 02:18 PM
I'm surprised. It was exactly the opposite for me. The spool didn't make any noticeable difference.
I also have skinnies up front and I still think it's a lot harder again not impossible but a big difference.
~Jim~
Old May 5, 2013 | 07:40 PM
exodus_gs1's Avatar
I have chewed on this idea a lot, what about something between a 225-245? I use mine as a dd just until I pay it off. Would this be something worth doing sooner then later? I'm trying the save weight without being noticeable by others
Old Jul 18, 2013 | 02:41 AM
fastsspr's Avatar
Question
Hi you installed your rack ? How it Works?
Thanks
