60 feet is not good, NEED HELP
I went to Milan last Sunday 45 degrees out the track was hooking good,tires at 15.5lbs. My first run 11.88@119MPH 60 foot 1.72. Then i do 2 more runs and I am launching at 3500 RPM and my 60 foots are 1.99 2.0 running 12.88-13.05 but my gas light came on. Can it be I ran out of gas because my last run the light was off. What would make it do that. PLEASE HELP.And my fuel pump wires were loose and I had to play with it until I got 60psi. Thanks Ken
What were you trapping on the 1288-13.05 runs? I go to Milan quite often, and can tell you personally that their timing equipment has been off on two occasions. Probably not the case here, but thought i'd mention it
