2nd gear burnout bogs down motor.
On street tires I can usually do a second gear burnout no problem.
I put on 275 nitto drag radials @ 18psi last week and went to the track. I rolled through the wet box and proceeded to do my burnout in second gear, I reved the engine up to about 3500 dropped the clutch and mashed the gas pedal. The tires started to spin the motor bogged down and i almost stalled out. My question is does my car not make enough power to do a burnout in second gear with drag radials or does something seem off?
It is two rev limiters. One is your normal rev limiter. The second rev limiter is activated when the clutch pedal s down (or line lock on), or the trans brake on, or a button on the foot brake pedal depressed in a foot brake automatic car. Used for consistent launches.
