Drag Racing Tech
why am i getting low 14's
Old Apr 27, 2004 | 10:58 PM
SLP/Drew's Avatar
Angry why am i getting low 14's
hey i got a 2002 M6 trans am with slp headers, cats, y-pipe, flowmaster exaust, and K&N and im running low 14 consistantly
My car isnt throwing any codes but im getting bad times whats up??
1st gear is practically useless becasue I cant get traction(whats the solution to that) but my e.t.'s are fine im getting around 105mph
HELP ME OUT HERE PLZ...do i need new tires,shifter,clutch or am I just bad, help me out any suggestions are helpful
Old Apr 27, 2004 | 11:04 PM
foff667's Avatar
LS1TECH Sponsor
probably, probably, probably not, maybe...tires will help alot with traction if you cant figure out how to launch it well...if your cutting 2.20 or worse 60' times you really should look into new tires, better shifter and maybe work on the launch ALOT...other than that its just seat time.
lata
Bill
Old Apr 27, 2004 | 11:07 PM
SLP/Drew's Avatar
thx man...i just get mad when i hear guys talk about running stock f-body cars that run mid to low 13 and im getting low and flat 14's...?!?!
Old Apr 27, 2004 | 11:30 PM
Krab's Avatar
Get some more practice, and tires will definetely help out your ET's. The best thing since your an M6 is getting used to your car though. Oh, and your trap speed is there, but your ET is not.
Old Apr 27, 2004 | 11:33 PM
SLP/Drew's Avatar
thx...ive made about 8 passes, 14 is pretty high considering ive had the car for about 6 months...oh well thx for the advice
Old Apr 27, 2004 | 11:35 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
What are your 60' times? They must be around 2.3+
For every .1 off your 60' time, discount .15 sec off your ET as a rule of thumb.
Old Apr 27, 2004 | 11:48 PM
SLP/Drew's Avatar
WOW...didnt know that...I WANT YOU ALL TO CHECK OUT MY OTHER POST
its right below this one and it has one of my tickets from the track...its pretty consistant...but my 60' time is 2.4 and above whenever I go
THX guys keep it comming im learning a lot
Old Apr 27, 2004 | 11:57 PM
jdp244's Avatar
when i started last year at the track i had similar problems. I had no horsepower mods and crappy 60' times. It is hard to get them on stock tires(thats why i just got nittos). BUt one other thing that i found at the end of last season was that i was shifting a little too early. But like the guys said nothing helps like practice. Good luck
Old Apr 28, 2004 | 12:10 AM
jrp's Avatar
jrp
SN95 Director
its all about practice, plain and simple. your trap speed and e.t's are low.
Old Apr 28, 2004 | 02:41 AM
70 TA's Avatar
I read you post with your times on the other thread.
Your MPH seems a bit low. Did they tune your PCM after the header install?
From what I know any long tube install requires tuning as it leans out the A/F ratio.
For comparison I just timed my 2002 SS M6. I am a bit disapointed with the times but I'm running the stock Goodyears so zero traction from the line.
3 passes spinning almost all the way through 1st and the 14.02 included wheel hop
13.92 @ 106.5
13.94 @ 106.5
14.02 @ 106.3
The car is all stock except for MTI Lid. Still have the paper filter in since my Holley powershot is in the mail
I am very happy with the MPH though indicating that the power is there. I figure with drag radials and a few suspension mods my car should run very low 13's easy.
Old Apr 28, 2004 | 01:11 PM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
I never drove standard before and with a slipping clutch at the top of 1st gear I managed a 2.2 60" on stock 17 inch BFG tires and a 13.3x @ 106 mph. Dyno and Autotap the car if you think something is physically wrong with it, aside from that ..... to be honest, learn to drive.
Old Apr 28, 2004 | 01:17 PM
!LS1 11 Second Club
When my car had only LT's and a lid, I whittled my times from 13.9 (first time to the track) to 13.01 by shear practice and doing some research on launching. The end result was not stellar, but it was almost a 1 second improvement.
