Drag Racing Tech
What should it run
Old Jul 22, 2013 | 07:35 PM
cantfind2nd's Avatar
Default What should it run
Completing my project wondering what it should run , 2002 z28 stock short block , ported 241s , ms4 cam , ported oil pump , billet timing chain , harland sharp roller rockers , all tsp valvetrain , eldelbrock vic intake ,elbow , 90mm tb 42# injectors , carb nitrous plate kit 150 shot ,built th400 4000k stall 3.55 gears narrowed 8.8 swap , all qa1 single adjustable shocks , no sway bar front , drag bar rear , sphon offset lca ,340 pump , long tubes , true duals , single chambers . some weight reduction . billet specialties bigs and littles 275 60 15 mt drags. will be dyno tuned. Any clue what it should run? Thanks
Old Jul 22, 2013 | 07:53 PM
HCI2000SS's Avatar
Maybe high 10's or so if you hook. That's my guess
