Drag Racing Tech
exhaust
Old Jul 20, 2013 | 10:27 PM
stherngent's Avatar
Default exhaust
Would an exhaust system restrict flow enough to slow down on top end? Like 3-4mph and 1-2 tenths.
Old Jul 20, 2013 | 11:34 PM
stherngent's Avatar
I had a slp lm with tsp 3" ory, with that set up I ran 93.90 mph 7.5 in the 1/8, I changed to a tsp true duels I am now running a 89.50 mph 7.7 in the 1/8, during the time I did the change I also had my converter tightened up a lol bit. So at 1st I thought that was what changed it but I've had it loosened up a lol bit not like it was but nothing changed their my 60'ft were still pretty close 1.7 to 1.6..........
Old Jul 21, 2013 | 12:40 AM
TurboStangJON's Avatar
So you slowed down 4mph in the 1/8th switching to true duals? I would think its more of a converter issue. Why did you have it tightened? It might 60' the same but what it does down track may be totally different.
Old Jul 21, 2013 | 12:52 AM
stherngent's Avatar
It was way loose, I have nitrous on it and my tunner said it was blowing thru the converter, so I had it tightened up. Everything I've read and even the converter shop said that I should have gained more mph impunity lost. The only two other things I have done to the car is put a k/n ram air kit on it because I have a ultra z hood, I figured that would allow more air in than the slp lid, the other was changed my exhaust from slp lm with 3" ory to tsp true duels. I've read a couple post where they say the runnable bullets were real restrictive. Just looking for other opinions or experiences, thanks for any help or opinion
Old Jul 21, 2013 | 07:59 AM
Here's an easy wsy to check, take the mufflers off and run it down the track. What brand are the mufflers?
Old Jul 21, 2013 | 05:55 PM
stherngent's Avatar
Texas speed rumbler bullet, I'm starting to think it's the k&n cold air/ ram air kit. I billed the mufflers off and look thru them and a tennis ball would just about fall thru it. And might would I didn't have one to check it with. But I just don't see that being restrictive.
Old Jul 21, 2013 | 09:03 PM
Jason94z's Avatar
What are the fast track-only guys running?
I want to take off my 3" to 4" y-pipe and 4" mufflex cat back, and just run 18" collector extensions. Good or bad idea?
Old Jul 22, 2013 | 08:12 PM
Definitely not the mufflers, guy who owns my old motor has been the similar times as me with that exhaust.
Old Jul 22, 2013 | 09:31 PM
stherngent's Avatar
Yea I was starting to think it's the k&n ram air not getting enough air, if not that than might be my tune my timing is 27*
