Rollbar needed?
I have a T-Top 98 Trans Am
Any suggestions on a manufacturer?
This is something I will install and weld myself.
I would like to get a ChroMoly set-up.
thanks
However, you are allowed to bolt-in a rollbar.
The 2004 NHRA rulebook quotes: Unibody cars with stock frame and firewall may attach rollbar with 6-inch x 6-inch x .125-inch plates on top and bottom of floor bolted together with at least four 3/8 bolts, or weld main hoop to rocker sill area with .125 reinforcement plates, with plates welded completely.
As mentioned these are NHRA rules, I believe IHRA requires a 5-point bar at 11.50 to 9.50 with the same requirements on frame, floor and firewall restrictions.
Derek
