Lingenfelter LNC-2000 questions
Ive been looking at the Lingenfelter LNC-2000 controller on my camaro for playing around at the track. My question is what do you guys use to activate it? Is it possible to have it activate off the brake lights? Figured since im a stalled auto that would probably be my best bet. Any input is greatly appreciated. Thanks
Thanks for the replies guys but i wasnt going to use it for the bottle just for launching. I footbrake the car so i want a way to flat foot the gas right where the converter tightens up (1800ish) and then the controller cut off as soon as i move my foot off the brake pedal. Is this just a bad idea for what im trying to do?
I'm gonna wire mine to my line lock activation switch. I got a 15 amp toggle switch from O'reilly's and it's being used to activate the line lock circuit, and will be used to activate the launch control on my LNC box. It's gonna be wired from the clutch pedal switch to the toggle, then to the LNC so it only activates when the clutch in pressed in all the way.
