Drag Racing Tech
How much pinion angle on a nitrous car?
Old Aug 28, 2013 | 04:51 PM
ls1CANTU's Avatar
Default How much pinion angle on a nitrous car?
Would like to know what y'all nitrous guys are running on pinion angle?
Old Aug 29, 2013 | 10:48 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
Nitrous, blower, turbo... it really shouldn't matter. True driveline angles are more of an issue than "how much", and I will tell you now that more isn't always merrier. Correct suspension geometry(IC length/height), center of gravity point, shock settings are all things that play into how the car works.
A -1.5 to -1.8 pinion angle should be fine however.
Old Aug 29, 2013 | 11:52 AM
RENE'S RAGE's Avatar
Mine is at +2, is that too much?
Should I get it down before I go to the track?
Old Aug 29, 2013 | 03:57 PM
87silverbullet's Avatar
Each car is different. My car is lowered 1" and with stock location suspension my pinion angle is -2.5.
Old Aug 30, 2013 | 10:54 AM
blue99fbody's Avatar
we had a buddies car with all poly bushings set around -2.5 - -3* and my car with all rod end parts ~-1.5* both t56 n2o cars
