Drag Racing Tech
brake lines
Old Sep 1, 2013 | 11:21 PM
98hc4mula's Avatar
Default brake lines
Can anyone comment on making the front brake lines with stainless steel braided hoses? I dont want to use hard lines for th3 front. Are they safe for a weekend warrior.
Has anyone done this or is it nor recommended.
Old Sep 2, 2013 | 01:49 AM
Blown06's Avatar
8 Second Truck Club
I wouldn't do it. It'll make the brakes spongy. Use as little braided hose as possible. Why don't you wanna do hard line?
Old Sep 2, 2013 | 09:50 AM
98hc4mula's Avatar
I want to use an fittings because I have had to take the engine out a few times and hard kine fittings are so soft they dont seal right after a few times.
Also bc its easier to put together for me.
Old Sep 2, 2013 | 10:15 AM
chevelledave's Avatar
reroute the lines ..i can take my k member out without breaking the lines ..same on the rear end lines they run across the chassis not the rear end ...just got to remove and hang the calipers ...
Old Sep 3, 2013 | 12:11 AM
Blown06's Avatar
8 Second Truck Club
You can use an fittings on hard line. Just need to a 37 degree flare tool. Reroute the line out of the way. You should not have to break the brake line to remove the motor...
