First time running this car @ the track
I finally got a chance to run the car in my sig this week and I was having traction issues with it. My best was a 12.23 @ 113mph with a 1.8 60ft. I was wondering if I could get a few pointers from you guys. All my mods are in my sig, and here are a few things you should know:
-Lower control arms are set in bottom hole of relo brackets
-Torque arm is set in lowest position on relo crossmember
-Pinion angle is at -2*
-CE shocks are set at 50/50
-Drag radials are at 17psi
Any help getting my 60 ft down would be much appreciated!
Also today I just ordered a set of Viking front dual adjustable shocks w/300lb springs to see if that will help.
What is your rear gear (sorry if I missed it)? Front adjustable shocks should help some. Try break torque/flashing the convertor at different rpms to find what it likes. When you make adjustments only make one at a time and try 2-3 runs for each adjustment.
Something seems off with your mph - 410 at the rear wheels and those mods should mph higher then 113.
Yep you read that right. I wheel hop like crazy at 26 PSI. Chased the issue of inconsistency for awhile, adjusting suspension... getting new shocks... wasting my time.. Finally I realized if I kept tire pressure at 25 I didn't have an issue. Dead hookin even on street night with bare minimum prep.
Mine on the 11.80 pass was 93mph 1/8th and 114mph 1/4 but the car traps consistently lower than Fbodies in the 1/4 (likely due to aero and a 2-3 shift issue which has been fixed).
When the car was cam only and heavier it ran 12.24@111.5 MPH on a 1.68 60ft in cool air.
Well, I am heading to the track today to see how the car works now! I have installed the Viking DA front shocks as well as adjusted my torque arm up to the second to top hole in the relo bracket to change the instant center. With the new front shocks installed, I am going to try running more air pressure in the rear tires then the 17-18 PSI I was running before. My goal is to hopefully lower my 60' and pick up some mph as well. Stay tuned...
2000 DA isn't awful. Have you compression checked the motor to verify everything is running as it should?
Do you have a scanner on it that you can verify to see if any timing is being pulled on the run? Sometimes stupid things that can rattle or shake against the engine and you don't notice but your KR sensors do and they kill your timing...
