Drag Racing Tech
Height adjustment DA Afcos
Old Sep 9, 2013 | 09:04 AM
TXCatfish's Avatar
Default Height adjustment DA Afcos
Anyone know how to adjust the height on da afcos? I've got a spanner wrench so can I just jack the front end up off the ground? And is it just a turn of a adjustment nut???
Thanks
Old Sep 9, 2013 | 10:18 AM
03supercobra's Avatar
There should be a set screw in the spanner, loosen that. Then you just have to run up the spanner to compress the spring, lower it down and be good to go. Count threads or turns on each side to get them an even distance.
Old Sep 12, 2013 | 08:47 PM
transam69230's Avatar
I will set the driver side a little higher to offset the weight of the driver. This would be for drag racing.
Old Sep 18, 2013 | 09:22 AM
TXCatfish's Avatar
Just so I'm clear I marked the 2 pics with red arrows pointing at the screws I believe are the set screws. Is this correct??
Thanks!
