Drag Racing Tech
Best Drag Race Torque Arm
Old Sep 13, 2013 | 08:39 AM
Transam1's Avatar
Default Best Drag Race Torque Arm
like the title says, looking for a torque arm for my 99 trans am. car is 90% drag and 10% poking around town a little bit. I have the 9" and LCA's, PH-bar and all of that and now its time for the Tq Arm. car makes roughly 450 before spray to the wheels through and 5000 converter.
Am i better off with a tunnel mount, weld in type, or long arm not connected to the tail housing?
Old Sep 13, 2013 | 09:14 AM
Stroked96Bowtie's Avatar
I had a Midwest chassis body mount tq arm in my last car, never had an issue with it, worked great. Madman makes nice stuff too...hit up one of the sponsors.
Old Sep 13, 2013 | 09:48 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
^^^ I like what this guy has to say!
I have a proven working design that works great for street and strip cars. The MWC front mount design features a height adjustable pivot link design that is coupled to the arm with a aircraft grade heim joint to allow a bind-free suspension movement. The crossmember is a full bolt-in design and includes a driveshaft loop at no extra cost as well. Mild steel and Chromoly versions are available and in stock with choices of different crossmembers to work with your exhaust.
Give us a call and we can get you set up with the highest quality and the best prices.
Old Sep 13, 2013 | 10:34 AM
Transam1's Avatar
i guess my worry with the tunnel mount is that the area it bolts to does not seam very strong, or like it was ever made to take the pressure. only reason im debating the weld in type
Old Sep 13, 2013 | 11:24 AM
SuperSlow02's Avatar
The area where you bolt them is is just fine. Mines been there for 5yrs now with zero issue. 3pt subframe connectors will add strength there If your worried
Old Sep 13, 2013 | 11:27 AM
MYSTIC-1SC's Avatar
Another vote for Midwest Chassis tunnel mount setup. Plenty of abuse on mine with no problems!
Old Sep 13, 2013 | 12:09 PM
93camaro_zzz's Avatar
I have the Spohn Chromoly Chassis Mount with DS loop on my car. It has been awesome so far. Really beefy torque arm that is adjustable. I guess the ONLY problem I have had with it, is that I have a 9 inch also like you, and with the Torque arm adapter mount on the 9 inch, it pushes the torque arm forward a little, and the same for where it mounts to the crossmember. Luckily (I have checked) it still does not bind at all, but I guess it is not "optimal" I have the torque arm adjusted as far back as I can to prevent this.
Old Sep 13, 2013 | 12:25 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Call Madman at "Insane Chassisworks Inc" number is 409 225 5744.
He can get you hooked up with the best TQ around!
Coach
Old Sep 13, 2013 | 12:46 PM
ssvert99's Avatar
Thanks for the order! Rest assured you purchased the best parts you could.
Old Sep 13, 2013 | 12:51 PM
Great choice Dane!
Old Sep 13, 2013 | 02:00 PM
Transam1's Avatar
i think it was a good choice! Im pumped about the adjust ability where the arm bolts to the cross mount. gonna hammer them tires! lol
Old Sep 15, 2013 | 11:07 AM
flyinZ's Avatar
PM sent
Old Sep 15, 2013 | 05:55 PM
studderin's Avatar
If I was to buy a TA right now it would be a MADMAN
Old Sep 15, 2013 | 07:44 PM
1BAD98LS1's Avatar
I think most all of the body mount T/A's are going to be fine for 450whp cars. I've had good luck with a used spohn body mount T/A.
Old Sep 17, 2013 | 06:35 PM
black and pink z28's Avatar
There are umi ta on both of my car and like it a lot
Old Sep 17, 2013 | 10:53 PM
DEFYANT's Avatar
Even though he already bought it, another vote for Eric @ Midwest Chassis, his stuff is proven, and flat out works! The Ohio Boys, Ray Litz, Andy Essary, Brian Black, all 7 second rigs.
Old Sep 18, 2013 | 07:16 AM
Slowhawk's Avatar
LS1Tech Sponsor
I run Midwest short torque arm. consistant 1.2 60's here on DR's. Was worried if the mounting point was week too. Checked it a few times and it's all good.
Old Sep 18, 2013 | 08:52 AM
Transam1's Avatar
thanks for all of the info, really boosts my confidence! im going to start out with the arm in the second hole from the bottom where it mounts to the cross bar. Hope it helps my horrid 1.59's 60'
Old Sep 18, 2013 | 08:54 AM
ATVracr's Avatar
Coach
X2 !!!
Old Sep 18, 2013 | 10:10 PM
billybadd's Avatar
Madman and be done.
