28" or 26" tall rear tires for my combo
My setup is full bolt on,ms3 cam,4000 stall,175 shot,lowered,lca relo brackets, lca's, stock 10 bolt 3.23( 9" with 4.10 soon) just curious which tire size would be best. I love the stance a 28" tire gives but want function more than look. Thanks guys
With that low of a gear, you will want the smaller 26". It will get your powertrain rotating and up in the power band faster. When you go to the 9" with 4.10's, then look at a set of 28".. but I would try the 26"s first to see how the car reacts. If it seems you are pegging the red line all the way through, then go with the taller tire.
