battery relocate issue
ok ..Im gonna do my best to fix this ..use a ford starter relay ...positive in ..and positive out to the post on the starter ...jump a 12 gage wire from the postive post on the starter to S terimanal on the starter ..the original Purple 12 gage goes to the small terimnal on the ford Noid..i mount mine under the dash on the drivers side ..my car has a 13.5 to 1 BBC chevy and has zero cranking issues ...a neg cable from the battery to the chassis ..then chassis to block is needed as well
Are you using a cut off switch? This could be an issue as well. I had one that was defective and the car wouldn't start. Replaced the switch and everything worked fine.
and would not crank back after you just cut the car off.
I don't think that is his problem.
I think he has a weak battery and not getting enought
voltage to the starter, with the battery in the back of the car.
Here is all I did and works flawless ran 0 gauge from battery to the positive post on the fuse box area then ran 2 gauge from that post to the starter and ground the battery in the back works every time all the time
I had the same issue with mine when I did this. I fought and fought and finally tested the battery and it was weak. Put a new optima in it and boom, fired right up. I was using 0ga wire too. I'm not sure why but if your battery is weak, a relocation will let you know. Guess its all the extra resistance from the long cable. Idk.
The negative coming from the battery to the chassis needs to be just as big as the positive IMO. Seems to work best.
The neg cable needs to be as big as the pos cable.
