Drag Racing Tech
car willnt 60' like it did
Old Oct 1, 2013 | 06:34 PM
loosews6's Avatar
Default car willnt 60' like it did
well I had a progressive nitrous controller on my car took it off to leave on a 300shot first pass car left hard as hell almost when to bumper on the foot brake so I got out of it. every pass since then car willnt leave as hard and willnt 60ft willnt even pull the tires up. i tried 3 new full nitrous bottles... 408 stroker nitrous cam and ptc converter with th-400 induction solution black widow nitrous plate
3300 race weight ....got viking front and rear shocks trz anti roll bar 28x10.5 tuff side slick with tubes
help............
Old Oct 2, 2013 | 01:07 AM
stherngent's Avatar
Do you know what your psi was on the nitrous before and after the run? Did u purge before the run?
Old Oct 2, 2013 | 06:49 AM
loosews6's Avatar
1000psi don't no after the run yes purge and ran it thur the Motor...
Old Oct 2, 2013 | 01:04 PM
htownws6's Avatar
I went through this recently, check your torque arm and all the bolts (even the ones on top) that bolt the torque arm to the differential, make sure they didn't shear or back out. A hard hit like that can do that and you won't know about it until its too late.
Old Oct 3, 2013 | 12:55 AM
93camaro_zzz's Avatar
What sixty and ET were you running before, and what sixty and ET do you run now?
Old Oct 3, 2013 | 08:44 PM
loosews6's Avatar
1.28 now 1.40 60ft
Old Oct 4, 2013 | 12:28 AM
noice's Avatar
Originally Posted by loosews6
1.28 now 1.40 60ft
Is the motor bogging down when you leave? See if you can make some all motor passes and compare them to previous all motor passes.
Could be a converter issue.
Old Oct 4, 2013 | 09:53 PM
Dustin11's Avatar
If you have a T-400 and you peddled out of the wheelie in 1st gear you may have rolled the sprag in the transmission.
Old Oct 5, 2013 | 09:35 PM
loosews6's Avatar
fixed it..... nitrous express tps sensor sucks wired up straight to solenoids run 5.75 @121mph foot braking the car
