Which Slick for a Stick
I have a stick car and looking into bias ply. Which would would best best? I would like to go tubeless if possible and on a 15X8 rim.
26 or 28"
M&H
Hoosier QTP
Mickey ET
I have a 15X8 rim, 3.73 Rear end gear, Stick car. Can someone who has already tackled this headache assist? I can't even find a filter for "stiff wall".
Its actually a 26.5 inch tall tire, been running it tubeless. Just installed screws on the backside cuz the wheel was spinning on the tire.
cuz they break down each tire, compound, tread & sidewall width, tire height, recommended rim size for each tire.
Btw, you don't want to cross the traps in 3rd, you want to be in 4th.
You want to be crossing the finish line at the top of 4th gear, not just barely shifting forth. You want to balance your tire height with your gear ratio to give you max rpm in the top of 4th at the line, otherwise you are not optimizing your power. What's the point of having 4 forward (non OD) gears if you are really only using 3?
When I had 395hp I ran 4:11's and a 26" tire for a best of 11.32 @ 122. With 450HP it was the same tire and gearing for a 11.1 @ 125 (only ran it once) Just as a slight reference.
What RPM are you crossing the finish line at in 4th?
You are trying to decide stiff sidewall or not but it looks to me like you have not even sorted out your gearing.
Not trying to be a dick, but you are putting the cart in front of the horse a bit.
As for the stiff sidewall, with M/T (which is my recomndation) just look for the S at the end of the product code. I run the 3055S which is the 28x10-15 stiff sidewall. The 3055 is the same tire with a standard sidewall. Just look for the S at the end of the product code.
