Drag Racing Tech
Pulled the dash, 2 black boxes?
Old Oct 30, 2013 | 11:14 PM
Zmg00camaross's Avatar
Default Pulled the dash, 2 black boxes?
Well searched and couldn't get the answer. The One small box has two connectors behind the radio area mounted on the giant ducting. What is it? second would be I am guessing the BCM??? its on the r/s of the dash with a large connector. Otherwise pulling all the hvac crap and dash mat! Guessing plug up the vaccum line that goes to the engine bay. Any help would be great. EDIT!! I read you can remove the dash brace? The metal that goes all the way across? Seems dash would be supported the greatest.
Old Oct 31, 2013 | 12:07 AM
Orange99Z's Avatar
Bcm & the other is daytime running lamp module
Old Oct 31, 2013 | 08:22 AM
Seems I don't need the daytime running light module, do you need the bcm? This is a no power option car, crank windows no power locks etc.
Old Oct 31, 2013 | 08:43 AM
MichaelElsea's Avatar
Its the NSA tracking your driving habits.
Old Oct 31, 2013 | 09:05 AM
Then they will see I make a lot of passes down the track.
Old Oct 31, 2013 | 06:30 PM
Orange99Z's Avatar
Vats is in bcm & it has controls for the fuel pump relay.
Old Oct 31, 2013 | 08:23 PM
Bummer haha, probably the dash to possible. I will just keep both and not worry
Old Nov 1, 2013 | 10:44 AM
5.3LJimmy's Avatar
If you have the ability to disable the VATS with tuning software then you can get rid of the BCM. As long as you aren't concerned with interior lights and radio continuing to work. You need to ground a yellow/black wire that feeds a ground to the fuel pump relay from the BCM and the car will run(with VATS disabled in the PCM).
Old Nov 1, 2013 | 10:53 AM
Thanks man. Vats should have been disable when I had it tuned! Going to finish it up tonight. Was a pain to get to some of those bolts for the hvac box. But that bitch is out.
Old Nov 30, 2013 | 06:05 PM
black and pink z28's Avatar
if the daytime running lights box is not hooked up your turn signals will not workthat also controls them tooI found that out the hard way lol
Old Nov 30, 2013 | 07:21 PM
Lol I just left the 2 boxes. I tied them up. But not very good, first pass down the track the light module flys out and was between my gas pedal and floor haha
