Drag Racing Tech
need new drag tires
Old Dec 20, 2013 | 11:24 AM
M1SERY's Avatar
Default need new drag tires
needing new tires for my car to help out 60ft times,
rims are 10 inches wide x 15
looking at
HOOSIERS 18150 28x10 d06
HOOSIERS 18155 28x10.5 C06
M/T 3055s 28x10.5 m5
I know nothing bout drag tires Had been running a drag radial on a stick car if that tells you any thing
Need help which one of the tires you think is the best for me
Car is clutch car and weight 3500 lbs
Old Dec 20, 2013 | 11:30 AM
John Deere racer's Avatar
28x 10.5 S ET drag
Stiff sidewall is what u need to hook a stick car
Old Dec 20, 2013 | 12:57 PM
M1SERY's Avatar
Originally Posted by John Deere racer
28x 10.5 S ET drag
What rpm u leave at , and tire pressure ur running ?
What do u 60 ft?
Old Dec 20, 2013 | 03:56 PM
With 470rwhp
Old set up... Not whAts in my sig
1.39 60ft
18psi cold
6500rpm
Old Dec 20, 2013 | 04:43 PM
M1SERY's Avatar
With 470rwhp
1.39 60ft
18psi cold
6500rpm
very impressive John Deere racer maybe u could help me under stand this a little better
u mention I needed a stiff tire to get my car to launch, ok I see it works by looking at your 60ft times
My Question is why has everyone been telling me to get my ET street drag radial off my car and it will 60 ft better, there explained there are to stiff and not for a stick car.
Again I know nothing about drag tires
Old Dec 20, 2013 | 05:05 PM
Any slick will hook better than DR
A stick shocks them to hard
I have tried many tires...
The ET drag S
Stiff sidewall will hook for u the best
Even with stock suspension
Old Dec 20, 2013 | 05:16 PM
M1SERY's Avatar
The ET drag S
Do I need screws and tubes?
Old Dec 20, 2013 | 07:48 PM
NnOoSsSs's Avatar
The ET drag S
Good info for us stick guys
Old Dec 20, 2013 | 08:25 PM
Doug G's Avatar
Just wondering how your 60's are now ?
Old Dec 20, 2013 | 08:42 PM
M1SERY's Avatar
Best ever 1.62 track was phenomenal,on average 1.7 launching off the 2 step at 3900 rpm 14 psi on the 28 x 10 drag radial
Old Dec 20, 2013 | 11:57 PM
No
But I will screw these tires to wheels on this build
As im hope n for 1.2xs 60ft s with new set up N/A
Old Dec 21, 2013 | 04:59 AM
Doug G's Avatar
If it's dead hooking, I wouldn't think there would be much more in a slick ?
Guys are running deep into the 1.teens with MT DR's....and that's not even the pro tire.
I also know slicks just work better with a stick, but I don't like the top end squirm I got with a bias tire and low air pressure.
Old Dec 21, 2013 | 08:01 AM
M1SERY's Avatar
Good looking car Doug, Its not dead hooking I have tried everything to get it to go on the radial tire with not luck, if I drop the 2 step down to 3800 it bogs the car down, and if I leave at 4000 it spins real bad and wont recover, its the fastest at 3900 rpm and spinning some.
How low did you run your tire psi?
Old Dec 21, 2013 | 08:13 AM
M1SERY's Avatar
No
Does your car dead hook at 6500 or are you letting it slip a little to get wheel speed up ?
Thanks John Deere Racer, made my decision M/T 3055s 28x10 m5 compound, you have been a big help Thanks Again .
Hope you get them 1.2xs 60ft
Old Dec 21, 2013 | 08:53 AM
Clutch dump
It was barely spinning
Your welcome
Old Dec 21, 2013 | 10:45 AM
NnOoSsSs's Avatar
Clutch dump
Your welcome
Yesterday someone told me our m6 cars cant hook up, i need an auto i laughed
Old Dec 21, 2013 | 11:33 AM
Another key to hooking a M6 is
Make sure the car is level as much as possible
Old Dec 21, 2013 | 01:23 PM
ablakez28's Avatar
+1 for MT Drags with a Stiff sidewall
best 60 ft was 1.41 on a car that made 390rwhp and it would hook dumping from right under the limiter.
Old Dec 21, 2013 | 02:03 PM
BarneyMobile's Avatar
I been running the Hoosier 28x10.5 (C07) stiffwall slick with great results. So far my best 60ft on them is a 1.34
Old Dec 21, 2013 | 02:48 PM
NW Iowa WS6's Avatar
Wasted 2 years of my racing life chasing 60's with 275-315 26" radials and a stick. Never consistent just a "lucky" pass here and there. Typical day looked like 1.85 1.75 1.9 1.8 2.1 1.7 1.9 1.75 . Now with an et street bias 26x10 every pass is a 1.61-1.66 leaving about 6000-6400rpm. Still drive to and from the track 70 miles each way.
