Shaving Stock Valve Covers
I think the mounts recess into the valve covers some. I'll need to put some kind of filler in there, then sand down smooth.
Any help will be appreciated.
I would think any of the jb welds would work though.
If you are painting them then you can use body filler like evercoat or usg body filler to finish off the grinding scratches. If you can sand out the remaining area with a DA and 80grit paper, it will smooth the rest of the valve cover down for primer.
Give the valve cover a bath is thinner or min spirits before sanding and it will cut down on fish eyes when primering..
