Building of The Mistress
Now time for the new build
RHS block 427 with a whipple 2.9 supercharger backed with a braked turbo 400.
First I started by removing alot of unwanted weight off the car. Pulled seats, seatbelts, crap under carpet, door bars, all A/C and heat stuff, both air bags, cowl, wipers and motor, ABS, front and rear bumper supports, all hood latch stuff, stock steering wheel, stock shifter, front inner fenders and liners, all stereo components, not used wires, antenna, parking brake, cables and dust shields, throttle cable and cruise control and power steering.
So far I have installed a new 5" VFN sloped to windshield hood with Dzus fasteners
Kirkey pro race seat
Grant steering wheel and quick release hub
CM 6-point cage, will finish to 10 point
SJM Line Lock
I have ordered all Spohn adj. tubular
K-member
Solid motor mounts
upper and lower control arms
Pinto manual steering rack
QA1 18 way adj R series shocks with 275lb springs
What I will be ordering soon
Hurst pistol grip shifter/ custom bracket to use factory console
SJM ABS delete kit
front and rear bumper supports from MWC
battery reloc. w/box from Tick performance
Lonnies double pumper fuel pump w/ stage 3 lines
Spohn drag bar
Spohn tunnel mounted adj. Torque arm
Time for some pics
Now some of the tear down
Now a few of what is going back on the car
New gauge cluster
New hood and rails
So far that is all I have done and waiting on parts
