Drag Racing Tech
people running autometer tach's.....gotta question
Old 05-10-2004, 08:14 PM
30th t/a's Avatar
Default people running autometer tach's.....gotta question
i got a 5" autoguage tach by autometer, the the tach is 200 rpm off. the rev limiter is 6800 and going by the tach it come on at 6600. Im 100% positive its set at 6800. the guy at autometer say my ignition system is to weak for the tach at the high rpm's. i also heard the autoguage tachs arent as good as a regular autometer tach.
does anybody have problems with their autometer tach at high rpms? have you had to upgrade your ignition system?
i do have msd wires.
Old 05-10-2004, 08:20 PM
Slow 346's Avatar
Did you set the tach to 4 cyl. mode? If its on 8 cyl, it will be off.
Old 05-10-2004, 08:58 PM
30th t/a's Avatar
yes i t set it to the 4cyl mode.
Old 05-11-2004, 05:51 AM
30th t/a's Avatar
cmon people.
Old 05-11-2004, 08:39 AM
95 Formula's Avatar
is it brand new? Mine is off and I'm sending it back for a check up and a recalibration...but mine is older.
Old 05-11-2004, 09:30 AM
30th t/a's Avatar
yes it new.
Old 05-11-2004, 09:46 AM
95 Formula's Avatar
I would check it with a scanner compaired to what the computer sees your rpms at. But you are right..autoguage isn't as good as auto meter from what I hear.
