is this tire i put on going to slow me down????
AUTO with 3600 STALL
car, last time with a 150 shot, 3:73 gears, and 26 tire
60 ft: 1.5
1/8: 6.8
mph: 102
1/4: 10.6
mph: 124
the thing is my car sounded like it was hitting the rev limiter real bad right before the finish, so I went to a taller tire...
well now I got a 28" tire with tube, strange rear with spool, switched to a 200 shot, lost a bunch of weight with tubular front end everything.
well come to find out its my valve springs sticking just a bit, but my new tires are on already.
when I dyno it, it seems to fall on its face at the same spot with both the tires...
60 ft: 1.5
1/8: 6.8
mph: 102
1/4: 10.6
mph: 124
I doubt the tire will slow you down, but the MPH will be different at the various points down the track. Where you could pick up ET is hitting it harder out of the hole with the bigger tire.
Al
Al
I have the opposite prob, my 6speed car with our tracks subpar prep I'd love to up my 4.11 and 26x10 to a 28" but I'm already only crossing the line at 5900, I could go from 1.6s to 1.5's with the 28s but I'd be bogging 4th gear even worse and lose top end
