Afco 3870R rear shocks on my 2000 camaro?
I have a moser 9' with all BMR except for a spohn anti roll drag bar,
First problem: the larger bearing that goes in the head of the shock won't go threw the spacer bolt that connects the shock to the rear end housing.
Second problem: when I mock it up into place the adjuster but is large and is right up against the anti roll drag bar. Can't go the other way it will hit the lower control arm.
Need help and pics if possible! Thanks
Bryan Bishop/ 864-243-6249
LS1Tech Sponsor
Give us a call. We have a shock relocate bracket that will fix all your issues.
http://www.madmanandcoracing.com/sho...aspx?itemid=11
