Drag Racing Tech
Where the hell is my mph?
Old May 16, 2004 | 07:01 PM
goinbroke's Avatar
Default Where the hell is my mph?
My best run was a 11.82 @116.8 with the 231/237 cam. But i see alot of people trapping 119 to 121mph with this cam. Where the hell is my mph? If anybody can find it, please tell em to meet me somewhere. Lol.
Old May 16, 2004 | 07:30 PM
foff667's Avatar
LS1TECH Sponsor
m6 or auto?
Old May 16, 2004 | 07:37 PM
30th t/a's Avatar
whats your 60'? im going through the exact same thing and i think my problem is that im shifting at 6400-6500 and and i should be shifting at 6800-6900 which makes sense since my car peaks at 6500. you gotta be in the next gear about 300-400rpm passed where your peak power is.
goinbroke's Avatar
m6 with 3.73's shifting at 6600 rpm. Still on shitty tuning but i don't think i can pick up 4 or 5 mph with better tuning.
Old May 16, 2004 | 07:39 PM
goinbroke's Avatar
my 60's are pretty decent for a stock rear. I cut some 1.60's and 1.70's.
Old May 16, 2004 | 07:43 PM
30th t/a's Avatar
whats your raceweight?
whats the DA when you were racing?
your 60's are very good for a stock 10 bolt.
find out where your car makes peak power.
Old May 16, 2004 | 07:50 PM
goinbroke's Avatar
I need to find out my raceweight.
Old May 16, 2004 | 08:01 PM
Fred99LS1's Avatar
I'll second the importance of shift points. Before I installed the new shift light I was only trapping 91.xx in the 1/8th, now I trap 93-94 pretty much every run.
Also what is the altitude of your track, Fred
Old May 16, 2004 | 08:03 PM
goinbroke's Avatar
I need to find that out two. Sorry guys not much help with weight and DA.
Old May 16, 2004 | 08:14 PM
foff667's Avatar
LS1TECH Sponsor
if the conditions were different thats one thing...if your running your 12.08@116 in 40-50 degree weather & new cam/heads setup in new weather obviously theres gonna be some difference, also i know those gears arent best suited for that cam.
Old May 16, 2004 | 08:21 PM
30th t/a's Avatar
like fred said....i was trapping a disappointing 113mph before my shiftlight nexted weekend i installed a tach&shiftlight and i trapped 117 with hitting the rev limiter every shift, DA of 2560, 100% full wieght through the full exhaust.
i just found out i should be shifting at 6800-6900 so i got my rev limiter moved to 7100 and got some 4:10s installed. if i can get 120+ with my street trim setup in this wheather ill be happy as hell.
Old May 16, 2004 | 08:33 PM
foff667's Avatar
LS1TECH Sponsor
fwiw my setup peaked @ 6300 & i shift my auto at 6600
Old May 16, 2004 | 08:50 PM
GIZMO's Avatar
How tall of a rear tire are you running compared to the faster cars?
Old May 16, 2004 | 09:00 PM
goinbroke's Avatar
MT et streets 26x15x8
Old May 16, 2004 | 09:12 PM
Fred99LS1's Avatar
I run the MT et streets 26x16x11.5
Old May 16, 2004 | 09:15 PM
goinbroke's Avatar
Looks like your running the same times as me but you are trapping 120mph.
Old May 16, 2004 | 09:29 PM
foff667's Avatar
LS1TECH Sponsor
w/ a smaller cam & stock valves on his heads...thats why im thinkin your da is way off...his runs were done in jersey at atco.
Old May 16, 2004 | 09:37 PM
SilverGhost's Avatar
Motorboater
well, IMO for that ET your MPH is not way off, its acceptable. You can't go comparing your car to others with a similar cam, just too many variables. Unless those other cars were racing at that same track on that same day as you it doesn't mean a huge amount.
You might be surprised at what tuning could do for the car, if nothing else it'll help you find the shift points and what RPM you want to be trapping at, which could make you re evaluate your gearing and tire height choices.
You'll get it figured out, let us know
Old May 16, 2004 | 09:49 PM
taqwache's Avatar
let us know what happens when you go back to the track with higher shift points and DA/weight info. i have a similar cam and trapped 119 at 11.88 on a 1.88 60' with a M6 and 3.73s also. i dont remember the DA but it was hot and humid. not the best raceday there is. i recently installed a TH400 and am expecting to lose some MPH but hopfully i can get a better ET.
Old May 16, 2004 | 09:53 PM
goinbroke's Avatar
Thanks for the reply's everyone. I think i am going to Rapid this week and let Mikey tune it and see what it does. I know i need a rear so i can launch it.
