Drag Racing Tech
Which Class to Race in?
Old May 14, 2014 | 05:20 PM
ragtopz28's Avatar
Nothing more fun than running the guy down, get even, then waap, waap, waap, inching them at the stripe.
Old May 14, 2014 | 05:33 PM
RENE'S RAGE's Avatar
Sounds like a bracket racer to me .
Old May 14, 2014 | 06:30 PM
murphinator's Avatar
Originally Posted by Mystery Bird
Any advice for a guy that sleeps at the light? Last time out I averaged .082 in 8 test runs.
stage as shallow as you can and leave when the 2nd yellow shuts off , or deep as suggested above by a guy that cuts .020's (damn) I am usually .030's but only race once a year if I am lucky , probably best try both and any other suggestions you get before the actual event , everybody has what works for them between their ears but you definitely need to tighten that number up - the good news is you recognize that
Old May 14, 2014 | 07:02 PM
ragtopz28's Avatar
long time
Old May 14, 2014 | 07:11 PM
kazman's Avatar
Its really hard to go when a light goes out vs a flash. It's a .500 between second amber and the third. Thats a full second until the green comes on. I did set my 07 street mustang to go off the 2nd amber. Took a very shallow stage and off idle. Fly by wire took a long time to actually go. Still in good air I had to stagger stage (staged sideways) to increase rollout to slow the car. Advantage of off idle is that I could add a .020 to my RT by keeping my heal down and lifting my toe off the gas.
Old May 14, 2014 | 07:13 PM
kazman's Avatar
Unless the slow guy is holding .08 sees what your doing and dumps you between the mph cone and the stripe making you break out.
So you live in Fort Myers?
Old May 14, 2014 | 07:30 PM
ragtopz28's Avatar
True...but usually the slow guy has seen you coming and has his toenails on the fan blade.
Ft Myers for 28 years now
Old May 14, 2014 | 07:52 PM
kazman's Avatar
I'm in south fort myers 2 years lol . Off Winkler between Daniels and Gladilolis. plz forgive my spelling lol Do you visit Immoklee?
This may be a reason for us to and lie about racing.
Old May 14, 2014 | 08:03 PM
ragtopz28's Avatar
PMed you as not to hijack
Old May 14, 2014 | 08:11 PM
I had to stagger stage (staged sideways) to increase rollout to slow the car. .
new trick to me but makes sense... added to mental quiver lol
also agree hard to leave on light out vs on , practice a lot when red goes out on street ( keeping eye on peripheral) to get used to it lol
Old May 15, 2014 | 06:49 AM
Mystery Bird's Avatar
should of asked first lol. are you shallow or deep, trans brake or footbrake, and what launch rpm, front and rear tire pressures.
I usually stage as soon as the second light barely comes on, footbrake, RPM's 12-1500, front tires 38, rear tires depends on track that day but between 18 and 22.
Old May 15, 2014 | 09:27 AM
  #32
Zmg00camaross's Avatar
Try to deep stage then during time trials.
Old May 15, 2014 | 03:07 PM
  #33
Originally Posted by nj02z
You can always dump .1 or .05 but you can never make it up if you need to. What I mean is if you do not have a perfect launch or something else is not quite perfect and your down some on your et you are in trouble where as if you have .05 in the bank you can make it up. You do not need to beat anyone by a car length just 1 inch. That is what the brake pedal is for. Go on youtube and search( BE 00 Take 00 ) and watch some of the guys play the game.
Are saying that if I trial run a 11.0 I should dial a 11.05 or even 11.1? Then play that out in the end?
Old May 16, 2014 | 09:05 AM
  #34
kazman's Avatar
Deep stage so that you just put out the top pre stage light. If you a little red drop launch rpm 100-200 and or drop rear tire pressue by a pound.
Hold .05-.10 Run it out to the 1000' marker then adjust to take stripe by a small mov. Taking a car length will most likely give you a break out loss. Start adjusting (backing in or slowing down) at the 1000' mark and you can make 5-6 adjustments. Look across and try to put your nose (your face) even with the middle of your opponents windshield piller. Crossing at the finish there should give you a .019-.010 first to cross mov and a win.
Take your full out time slip (time run) and subtrack the 1000' ET from the 1/4 mile ET. This factor can be added to your elimination 1000' to give you a good ball park of what you would of run if you didn't lift\brake.
Its easier to drive the top end holding more not less. Less your catching (or being caught) too close to the finish line to respond.
