Drag Racing Tech
shank style rims
Old May 29, 2014 | 09:15 PM
M.BOZZ's Avatar
Default shank style rims
Hey guys, I was wondering if I need to use shank style rims for drag racing. I've been looking around but no answers. I have extened studs and using a drag radials. Its not a full time track car
Old May 30, 2014 | 01:06 AM
Blown06's Avatar
8 Second Truck Club
Whats a shank style wheel?
Old May 30, 2014 | 11:00 AM
M.BOZZ's Avatar
Shank style wheel ( rim ) uses long style lug nut that fits snugly into the rim with a washer and holds the rim from the out side, unlike a acorn wheel nuts that holds from the inside. I know, it sounds like I answered my own question. So my question still stands
Old May 30, 2014 | 11:20 AM
RENE'S RAGE's Avatar
If you have extended studs, you need the right lug nuts for the stud.
They have a washer made on to the nut. And they use an aluminum thick spacer, around 1", in between.
Old May 30, 2014 | 11:44 AM
Guitar's Avatar
Racestars use a shank style. You don't NEED to use them, but I suppose it does offer better holding for the wheel maybe.
Old May 30, 2014 | 02:38 PM
Thinking about it, I have extended studs on the front and they do have the open end shanks that the studs stick through. But my backs are like I describe above.
Old May 30, 2014 | 03:34 PM
M.BOZZ's Avatar
yes I have extended wheel studs ( 3 inch ) and im using 2 1/2 long lug nuts and they don't bottom out. So would this set up pass tech ?
Old May 30, 2014 | 05:57 PM
I don't see why not.
What rims do you have, do you have spacers.
post some pics.
Old May 30, 2014 | 06:03 PM
98Camarod's Avatar
"The thread engagement on all wheel studs to the lug nut, or lug bolts to wheel hubs, must be equivalent to or greater than the diameter of the stud/bolt. Length of the stud/bolt does not determine permissibility. (Example: A 7/16-inch stud must be thoroughly engaged through the threads in the hex portion of the lug a minimum of 7/16-inch.)"
Old May 30, 2014 | 06:16 PM
M.BOZZ's Avatar
http://i1266.photobucket.com/albums/...g?t=1401491290
Old May 30, 2014 | 07:55 PM
98Camarod's Avatar
Can't tell, but I've also never had anyone say anything about my studs even with stock wheel studs.
Old May 30, 2014 | 09:12 PM
I can't tell either, why do you have extended studs?
If the shanks don't recess into the rims, that's not going to pass.
Old May 31, 2014 | 09:05 AM
M.BOZZ's Avatar
These are summit stars and are the acorn style rims, got a good deal on them so I was just checking if I can use them. I'm not a racer, I just like to go out sometimes and have fun. Its just a 60 mile drive to the track so I wanted to know if these where ok
Old May 31, 2014 | 11:46 AM
It's all about having fun.
Get the right lug nuts for the rims.
If your trying to use your factory stock lug nuts with those rims it's not going to work.
Old May 31, 2014 | 01:38 PM
M.BOZZ's Avatar
Thanks, but the lug nuts I'm using is McGards cone seat just like my rims are cone seat also. I don't think tech would say to much anyways, I'm just a local, no braket type of guy and just want to have fun. Thanks again for your input.
