Drag Racing Tech
post# of runs before factory clutch failed
Old May 18, 2004 | 09:57 AM
Magred2001vette's Avatar
Default post# of runs before factory clutch failed
For those with moded LS1's post # of miles/runs before your factory clutch went out.
Old May 18, 2004 | 11:26 AM
bad2000ss's Avatar
My clutch took a dump at 14,500 miles. I only had a 3 dozen runs by that time. It did not "grenade" but from a dead stop it would slip terribly.
Old May 18, 2004 | 03:54 PM
BadAndy's Avatar
Mine went out at~68,000 miles. 13.0s at 114mph. That thing died a terrible death to, pieces of friction disc and one whole spring were found in the bellhousing. Screw you clutch.
Old May 18, 2004 | 04:09 PM
1320_PERFORMANCE's Avatar
Mines went out @ 12,xxx, w/ about a dozen runs @ the track.
Old May 18, 2004 | 07:36 PM
SilverGhost's Avatar
Motorboater
killed the first one at 22K, prolly a couple dozen track passes in the low 13's, high 12's.
second stock one was pulled 10K later, had a TON of passes on it, prolly couple hundred, all on drag radials, all mid 12's(on motor) and a couple dozen with a 200 wetshot on top of it. was getting worn but was still ok when pulled out.
Old May 18, 2004 | 07:51 PM
SMOKIN01TA's Avatar
mine started sliping after 10 passes.
